04-08-2023, 05:13 PM | #1 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Want more NA power
Currently have cammed 15 ss. What is the latest and greatest heads/cam/stroker options? I know most people are just throwing on a 2650 so considering that too.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
04-08-2023, 07:10 PM | #2 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Tons of head options. If you don't mind the down time, just get the stockers ported. You'll then need accompanying valvetrain. Where you're at you've got to seriously plan on what you want to do with it. Anything else gets pricey. I'd spend my money on parts to make the stuff you have work better.
04-09-2023, 12:27 AM | #3 | |
weSS1LEy
04-09-2023, 05:36 AM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I wouldn't forget about compression. 11.1 is a good place to be.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-09-2023, 06:28 AM | #5 | ||
Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails.
04-14-2023, 06:31 AM | #6 |
Drives: 13' 1LE Join Date: Apr 2012
I would try FED heads, high ram, any stroker with decent compression will crack 600rwhp with a decent cam
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-14-2023, 04:27 PM | #7 |
weSS1LEy
Which one? Their m311? Or ls7 style?
04-14-2023, 11:02 PM | #8 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Just boost the damn thing.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-15-2023, 03:40 PM | #9 |
Drives: 2015 camaro 2ss, 87 monte ss Join Date: Jun 2016
Yep, I have come to that conclusion as well. Boost is the way to go. You have two main options. Big cam big cubes or mild blower set up. As for driveability boosted can't really be beat.
I love the idea of big cubes all motor. But there are guys running mild cam, no head work on just well setup lsa builds pulling 10s easily and driving those cars all over the country. Ultimately, boost from supercharger or turbo is the way to go. Just depends on how deep your pockets are.lol |
04-20-2023, 09:34 AM | #10 |
I would try a LS7 top end for the cool factor but honestly you can make ton of power with their M311
13' 1LE
