Roto-Fab
Old 09-08-2020, 03:56 PM   #1
BenZumeri
Drives: Chevrolet Camaro
Twin or single turbo?
I have been back and forth on either supercharging or doing twin/single turbo on my 2010 SS camaro LS3, I have leaned more to doing a turbo set up, my question is, should I twin turbo or single turbo what is more worth it for a lot of fun and power? Which overall is better for me to do?
BenZumeri is offline   Reply With Quote
Old 09-08-2020, 04:04 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Most do twins on the car's quicker spooling. If you aren't planning on doing over 1000whp you'll like the low end grunt of a supercharger though. I'd only do twins if i was going for 1000whp plus personally. It's all in preference though.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 09-08-2020, 04:09 PM   #3
BenZumeri
Thanks! Overall what do you think is best then If we’re talking turbo vs supercharger? I’ve been having such a hard time deciding which one because they both sound like a lot of fun
Old 09-08-2020, 04:16 PM   #4
mikeman
Drives: 2015 Camaro
Twin turbo all the way.
mikeman is offline   Reply With Quote
Old 09-08-2020, 04:18 PM   #5
BenZumeri
And why is that? What do I benefit and why is it the route I should take over a supercharger?
Old 09-08-2020, 11:37 PM   #6
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Street cars are more fun with top mounts. I do more driving under 4,000 rpm than above. So I can feel the TQ much more often.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 09-09-2020, 12:02 AM   #7
BuddyLee
BuddyLee's Avatar
Drives: 2013 Camaro 2SS/RS
A turbo is a touch slow off of the line. However, if you can get the boost and hold with a line lock or brake they lift off nicely. I had read that the turbo on the Buick 3.8L V6 doubled the cubic output. If you get a chance to look at the GN turbo you will notice how big it is.
BuddyLee is offline   Reply With Quote
Old 09-09-2020, 12:06 AM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Let’s just open this can up...
If you have decided turbos are your avenue to fun, cool. My personal opinion, twins is the way to go..
I have a little experience with them...
What are your goals...?
Do you have a builder tuner in mind, or are you doing this project on your own...?
What kind of “fun” are you looking for... ?
How much “power” are you looking for...?
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 09-09-2020, 12:11 AM   #9
Vegas Bound
Drives: 2013 Sparkly Red One
Procharger.
Vegas Bound is offline   Reply With Quote
Old 09-09-2020, 12:17 AM   #10
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Originally Posted by Vegas Bound View Post
Procharger.
The tur-blo... uhm...
Turblower,
Turbo,
Blower,
Turbo-supercharger... lol...
Old 09-09-2020, 06:24 AM   #11
BenZumeri
Turblower,
Turbo,
Blower,
Thanks everyone for your input! I believe I’m going to go twin turbo mainly to do something a little different and I would like to end up getting a lot of power later on so I would like to keep my options open on how much I can go, twin turbo it is!
Old 09-09-2020, 08:31 AM   #12
11-Camaro
Drives: 11 Camaro SS, Ninja 1000, Santa Fe
Turbos all the way. Consider a stall as well and there will be no slowing off of the line.
11-Camaro is offline   Reply With Quote
Old 09-09-2020, 08:43 AM   #13
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
I haven't done any FI on my car but when I do it will be twin turbos. My reasoning is AGP makes a great kit, twins typically spool faster than a single and I want the ability to select power (boost) on fly. Turbos you can cruise around on spring pressure at whatever power level that may be for your build and someone or something comes along that requires way more power and at the turn of a knob or a few presses of a button you have more power.
CamaroDreams76 is offline   Reply With Quote
Old 09-09-2020, 12:40 PM   #14
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Realistically for our cars engine size, twins are better suited. It’s hard to get a single turbo that is big enough in the engine bay without major reconfigurations. That’s why there are no cookie cutter kits available. Hurons single kit (which I have and is very nice) is only sized for a T4 frame. You can put 2 T4s under their (or AGPs twin bottom mount kit).
There is a single kit AND turbo in the classifieds for an unbeatable deal right now.
joshnmn is offline   Reply With Quote
ls3, ls3 5thgen, turbo, twin turbo
