Roto-Fab
Old 03-15-2014, 08:47 PM   #1
62nalide
62nalide's Avatar
Drives: 2013 SS
procharger F1 feedback?
Thinking on jumping on one next spring but would like feedback on this, the likes and hates.
62nalide is offline   Reply With Quote
Old 03-15-2014, 09:20 PM   #2
Unreal
Drives: 2006 Z06
Which one? A,C,R,X? I wouldn't do anything but an X. I like the Ysi/Novi 2200R much better for anything 1050rwhp or less, but for 1100+ the F1X is a nice blower.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 03-15-2014, 09:31 PM   #3
62nalide
62nalide's Avatar
Drives: 2013 SS
Anyone would work, just want a good blower I wanna be around 800-1000rwhp
Old 03-15-2014, 10:40 PM   #4
forklord
forklord's Avatar
Drives: 2010 2SS
if youre hitting 11 seconds with bolt ons, what you gonna get with a blower?? weeeooo
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
forklord is offline   Reply With Quote
Old 03-16-2014, 12:16 AM   #5
LSXaddict
LSXaddict's Avatar
Drives: 1ss in Blue Ray Metallic
Faster
2013 1SS M6 with Flowmaster Pro 10 axle back and CAGS shift skip eliminator
LSXaddict is offline   Reply With Quote
Old 03-16-2014, 02:40 AM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
Aiming for 10s with a VVT cam before I get a blower but yeah me want fast car lol
Old 03-16-2014, 11:10 AM   #7
Unreal
Drives: 2006 Z06
Turbos....
Nick
Old 03-16-2014, 12:53 PM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
Turbos....
I had a turbo truck making over 800rwhp and driving it around town sucked
Old 03-16-2014, 03:40 PM   #9
Rdunn
Really, Really Fast
Rdunn's Avatar
Drives: 2010 Camaro SS
for that power range a ysi would be about the perfect blower. if you plan on adding cubic inches to the motor you will make the f1x a lot happier
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
Rdunn is offline   Reply With Quote
Old 03-16-2014, 08:09 PM   #10
moiy1983
moiy1983's Avatar
Drives: 2010 camaro ss/rs
I have a F1-C Procharger on a 416ci. When it was at 14lbs it was at 842rwhp 733rwtq. I just installed alky meth kit & 17lbs its 902rwhp and 819rwtq with +17* total timming. Pros are obvious it pulls extremely hard and very streetable. Cons are at the most the cost and maybe a little clearance needed for the fender.
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian
LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads
ProCharger F1-X
Nitrous Outlet Direct Port
Fore Innovations Triple Pump on E85
Alky Control Meth Injection
ProEFI ECU
Stainless Works 2" Headers with Corsa 3" Exhaust
RPM 4l80e with Jakes Transbrake
BMR Everything with 15" Conversion
Zl1 Front Brakes & Carlyle Racing Rear Brake Kit
Weld Wheels
moiy1983 is offline   Reply With Quote
Old 03-17-2014, 12:05 PM   #11
Kelly@PCMofNC
Drives: 2010 RS/SS
We run the F1R on this car - 2010 Camaro 418ci
It's been a great blower for us, but beware the bracketry from Procharger. We run a cog drive on it and at first had the worst time about the belt walking forward under high RPM due to the bracket flexing. Procharger does not have a solution to this and I'm sure others have found themselves in the same position - we fabricated our own three point bracket with a turnbuckle to locate it back to the cylinder head...no more deflection! Here's what we did,
The car makes somewhere around 900-1000rwhp depending on how it's pullied, and it drives like a total baby, seriously. It whipped out a bunch of low 6's in the 1/8th and then the owner drove it to the movie theatre.
Kelly@PCMofNC is offline   Reply With Quote
Old 03-17-2014, 12:43 PM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
Damn! That's awesome!
Thanks for the quick response fellas.
Old 03-17-2014, 03:27 PM   #13
Unreal
Drives: 2006 Z06
If you have nothing right now, I would look at doing an ECS kit with Ysi if you are set on a blower. No bracket flex, easy 1000+rwhp if needed.
Nick
Old 03-17-2014, 04:20 PM   #14
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
X2.
BLACK10 is offline   Reply With Quote
