06-03-2013, 07:41 PM | #1 |
Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
Tuners: where do you set shift point on L99
Just wondering what is considered safe on the L99 with stock cam and AFM lifters. I recently had a blower installed and the car got dyno tuned as well. The shop says the rev limiter is set to around 6650 RPM, and the shift point in sport mode is at 6500. Can the lifters handle this? I'm not constantly redlining it, but I'm not always babying it, either
06-03-2013, 08:01 PM | #2 |
Drives: none Join Date: Aug 2011
Was it still making power up there?
06-03-2013, 08:41 PM | #3 |
Wow, usually even with some revised vvt tuning the power will fall off past 6200. On the stock cam, the lifters will live probably for a little while, but I usually set shift points to around 6100 rpm.
06-03-2013, 08:47 PM | #4 |
Here's the graph. It's definitely past peak, but even at 6500, it's still making well over 450 HP.
06-03-2013, 08:58 PM | #5 | |
Drives: 2010 Camaro Join Date: Feb 2010
Just food for thought. |
06-03-2013, 09:24 PM | #6 | |
06-03-2013, 09:30 PM | #7 |
I'd tend to factor out that little "hump" at the end and look at it as an actual curve. That said, I'd think you'd want to be shifting that thing around 6200 or so.
06-04-2013, 10:00 AM | #8 |
Drives: 2010 IOM RSS Join Date: May 2009
You want to shift a bit past peak to keep the car in the meat of the power curve. With that dyno sheet I would say 6400-6500 RPM but the DOD lifters aren't going to like that for too long..
A custom cam would really wake that thing up and get you away from the AFM/DOD stuff! |
06-04-2013, 10:24 AM | #9 | |
Do you think the maximum shift point that the lifters can safely handle is 6200 rpm?
06-04-2013, 01:24 PM | #10 |
Drives: 2011 Camaro 1SS Join Date: Dec 2011
do the conversion and have peace of mind
06-04-2013, 01:26 PM | #11 |
and a cam would not only "wake up" but it would unleash a monster if you added one with an FI application.
http://www.camaro5.com/forums/showth...dle+blower+cam |
06-04-2013, 02:21 PM | #12 |
Shop confirmed that shift point is set to 6500 rpm in sport mode. They said this is how they set all the Camaros. Not sure what to do. Everything was just torn apart for the blower install, so I don't really want to go through all that again so soon, just to do the conversion. Plus it's not cheap. If peace of mind is all I want, it seems like it would be a lot easier, less expensive and time consuming to just lower the rev limiter and shift point a little.
**edit** I'm thinking of asking them to set the shift point to 6200 and the rev limiter to 6400. Does that sound reasonable, and a little safer?
06-04-2013, 07:19 PM | #13 |
Drives: CTS-V Wagon Join Date: Feb 2012
That table does nothing for your shift points. These tranny's shift by MPH not RPM. Yes, I know this can be confusing but it's true...you can set it to shift at 10000 RPM but if your WOT 1-2 shift is set at 30 MPH that's when it will shift.
IMO, you have to spend some time fine-tuning the shift points on the 6l80e as you also have to consider your converter and even your tire due to traction issues...you have to lead into the shift. With my setup, my 1-2 is at 29 MPH because I know my RPM's climb close to 6900 (HPTuner logging) during the shift. I also utilize torque management - some shops turn it off. That was probably more than you wanted to read but it is what it is Experts correct me if I'm wrong as I'm speaking from my personal experience. |
06-04-2013, 07:52 PM | #14 |
I'm no expert, but certain T42's definitely don't shift JUST based on MPH. Mine is one of them. 1-2 is almost purely based on mph, but my 2-3 and 3-4 are shifting based on RPM.
