Roto-Fab
Old 05-12-2013, 11:11 PM   #1
1sick7
Drives: 2012 camaro convertible ss
What do you think cause this ,,,,,,,,,,,,,,,,
i installed a blower cam
dod delete
vvt delete
procharger kit
result ,,,,,,,
1sick7 is offline   Reply With Quote
Old 05-12-2013, 11:17 PM   #2
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
detonation
#5 - 2010 2SS/RS MN6 ABM #142-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 05-12-2013, 11:25 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I cant really see the pic very well on my phone but I would guess bad tune, not enough fuel supply, or bad gas. Those 3 key elements are vital, VITAL for a long lasting setup on boost. I am sorry for your loss but I feel your pain because my motor needs rebuilt or replaced as well.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 05-12-2013, 11:25 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
hate seeing this. Sorry bud I had that happen to me but I leaned mine, not enough fuel
62nalide is offline   Reply With Quote
Old 05-12-2013, 11:33 PM   #5
1sick7
:( i didnt even get to enjoy it lol
i havent enjoyed the car period the actual car only has 1800 miles
Old 05-12-2013, 11:34 PM   #6
1sick7
Originally Posted by 14pilot View Post
detonation
that's exactly what i was thinking
Old 05-12-2013, 11:37 PM   #7
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Looks like a detonation issue to me as well, how much boost? Certainly doesn't appear to have had ptv clearance issues.
Rhino79 is offline   Reply With Quote
Old 05-12-2013, 11:40 PM   #8
chevybowtie
Drives: 2010 Camaro
Stressed top ring lands. When boosted you what more loose on the top ring land. Especially in an alloy block. Detonation would be more of a burn or melted spot or spotting.
chevybowtie is offline   Reply With Quote
Old 05-12-2013, 11:42 PM   #9
14pilot
14pilot's Avatar
Not from being lean because the pistons start to melt on the exhaust side before they go and I don't see any melting where I'd be looking for it.
And as noted above, there is no PTV contact evidence. Cast pistons and just how much boost is a good point too.
Old 05-12-2013, 11:46 PM   #10
Rhino79
Rhino79's Avatar
With good tuning you can run 12 lbs on these engine no problem, but it can't have any knock. If it does, the hypereutectic piston will have a come apart. Did the rings butt together? Are the ring end gaps shiney like they have touched on the top and 2nd ring?
Old 05-12-2013, 11:57 PM   #11
1sick7
negative :/
i was running stock boost setting on the carb legal kit
Old 05-12-2013, 11:58 PM   #12
1sick7
I want to find out the cause to prevent it next time
Old 05-12-2013, 11:59 PM   #13
Rhino79
Rhino79's Avatar
Do you know what the afr and the timing were set at for wot??
Old 05-13-2013, 12:04 AM   #14
1sick7
negative
