Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 07-13-2016, 09:03 AM   #1
RPI Designs
RPI Designs's Avatar
Drives: 2016 SS 6 Spd
Custom Painted 6th Generation Camaro Underhood Parts From RPI Designs
2016 Camaro 6th Generation Custom Painted V6 Engine Cover $275.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro painted V6 engine covers are a great way to add some pop to your Camaro's hood. We buy brand new GM engine covers, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro V6 Engine Cover.
Because these items are custom painted to order we do ask for additional time from order date to ship date.
This engine cover is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
These V6 Engine Covers is available in two finishes:
Standard, which has a slight texture, as shown
Smoothie, which is a glass-like finish, no texture
http://www.rpidesigns.com/shop/item....over-two-tone/
2016 Camaro 6th Generation Custom Painted V6 Engine Cover $189.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro painted V6 engine covers are a great way to add some pop to your Camaro's hood. We buy brand new GM engine covers, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro V6 Engine Cover. Please select the color you'd like below, the main photo is shown in Red Hot.
http://www.rpidesigns.com/shop/item....-engine-cover/
2016 Camaro Custom Painted Engine Radiator Shroud $132.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro some attention with this custom painted engine radiator shroud. We use original GM shrouds, sand them smooth and finish them in our glassy smooth painted finish. Each 6th Generation Camaro radiator shroud comes in your choice of exterior body colors as well as hydro carbon fiber.
Because these radiator shrouds are custom painted to order we do ask for additional time as stated on the top of this page.
http://www.rpidesigns.com/shop/item....diator-shroud/
2016 6th Generation Camaro Custom Painted Engine Fuel Rail Covers Overlays $199.49 with code PHIL5 at checkout
Save some money and save some time with RPI's new 2016 Camaro Fuel Rail Cover Overlays. These overlays are exactly as the name implies. They are ABS plastic covers that attach directly over top of your factory fuel rail covers. These overlays come in any 6th Generation Camaro color, with custom lettering of your choosing.
Because these fuel rail covers are custom painted to order we do ask for additional time from order date to ship date.
These 6th Gen Camaro fuel rail covers are ABS plastic overlays and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....vers-overlays/
2016 6th Generation Camaro Custom Painted Engine Plenum Cover Overlay $185.25 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted plenum cover comes in a glassy smooth finish. This plenum cover is an overlay that attaches directly over top of your factory piece. Because this plenum cover is custom painted to order we do ask for additional time from order date to ship date.
This plenum cover is made and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....cover-overlay/
2016 6th Generation Camaro Custom Painted Engine Plenum Cover OEM $246.05 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted plenum cover is available in a texture. This plenum cover is a direct replacement GM piece, you'll need to remove yours and replace it with this one. Because this plenum is custom painted to order we do ask for additional time from order date to ship date.
This plenum cover is OEM GM and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....num-cover-oem/
2016 6th Generation Camaro Custom Painted Engine Fuel Rail Covers $265.05 with code PHIL5 at checkout
Set your 2016 6th generation Camaro apart from the crowd. Our SS custom painted fuel rail covers are available in a textured finish or hand sanded to a SMOOTHIE finish and come pre-painted in any 2016 Camaro body color. We also hand paint the CAMARO letterings on each set of 2016 Camaro fuel rail engine covers. Because these fuel rail covers are custom painted to order we do ask for additional time from order date to ship date.
These 6th Gen Camaro fuel rail covers are OEM GM and painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....l-rail-covers/
2016 Camaro 6th Generation Custom Painted Engine Strut Braces Set $189.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro strut braces are a great way to add some pop to your Camaro's hood. We buy brand new GM engine strut braces, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a set of 6th Gen strut braces for your 6th Generation Camaro. Sold as a set, one left and one right brace.
This set of strut braces are painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....ut-braces-set/
2016 Camaro 6th Generation Custom Painted Engine Dipstick - Available for Turbo, V6 and SS V8 $47.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro hood struts are a great way to add some pop to your Camaro's hood. We buy brand new GM oil dipsticks, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro oil dipstick. These are available for 4cyl Turbo, V6, and V8 SS. Please select your model below.
This dipstick is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....gine-dipstick/
2016 Camaro 6th Generation Custom Painted Engine Caps $94.99 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro engine caps are a great way to add some pop to your Camaro's hood. We buy brand new GM engine caps, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a 6th Gen Camaro engine caps. These are available for 4cyl Turbo, V6, and V8 SS. Please select your model below.
This set of engine caps is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
http://www.rpidesigns.com/shop/item....l-engine-caps/
2016 Camaro 6th Generation Custom Painted Hood Struts Set $66.49 with code PHIL5 at checkout
Give your 2016 6th Generation Camaro a new look. Our 2016 Camaro hood struts are a great way to add some pop to your Camaro's hood. We buy brand new GM Hood Struts, sand them smooth, primer them, paint them and put three layers of Dupont clear on top for a show winning shine. You will not find a nicer finish on a set of 6th Gen strut braces for your 6th Generation Camaro. Sold as a set, one left and one right strut.
This set of struts is painted in-house. We have over 70 years combined Camaro and Corvette painting experience, you won't find better quality anywhere!
Want to make your 6th Gen Camaro even more unique? We take these painted struts a step further. You can add your own custom text/phrase. We will cut vinyl and place your custom text on the outside of each strut....This way when a spectator at a show comes up from the side of your car they will see the statement your making right away! Please choose your lettering color and wording.
http://www.rpidesigns.com/shop/item....od-struts-set/
2016 2017 6th Gen Camaro Billet Aluminum Exact Fit Custom Painted and Etched Engine Caps Package $199.49 with code PHIL5 at checkout
Please remember these are custom made to order and do take a little additional time to ship out.
RPI Designs is proud to announce that we recently purchased the original NakidParts billet aluminum engine caps business. Many of you in the Camaro hobby may not know that Ed created the best looking, best fitting and best quality engine caps available for the C5 and C6 Corvette. With Ed's original design and RPI's man power, we are excited to bring you the original finishes and a few new finishes to these same great engine caps for the 6th Generation Camaro. We worked with Ed at NakidParts to make sure these caps were exactly right and what you've come to expect over the years. We purchased the cap business from Ed and we are very excited to build on what he started.
This kit includes covers for:
Brake Reservoir Cover
Coolant Tank
Washer Tank
Oil Fill
These engine caps highlights include:
Billet Aluminum (Heavy)
Made 100% in the USA
Exact Pressure Fit (put on without tape or choose to use tape if you'd like)
Available in all body colors
Available with custom etchings and lettering colors
As these are made to order we do ask you to allow us additional time from order date to ship date.
2016 2017 Camaro 6th Gen Painted Complete Engine Package $660.00 with code PHIL5 at checkout
RPI Designs is proud to release our brand new pre-painted engine dress-up package. This package is designed for the 2016-2017 Camaro SS only. We have been building and painting modern day muscle car parts for over 20 years. We make and paint all of our parts in the USA. No parts made in China or Taiwan, etc. All of our covers are made with ABS Plastic and are attached with 3M tape. All of our parts carry a 100% satisfaction guarantee or your money back.
Because of the custom nature of this product, please allow additional time for us to paint and ship your order out.
This 2016 2017 Camaro engine package is pictured with optional painted plenum cover and radiator shroud. These painted parts are not included in the standard package.
Custom text is available for the Fuel Rail Cover Overlays. No obscene words will be applied.
Custom billet caps are NOT included with this painted engine package.
Our kit includes:
RPI Fuel Rail Cover Overlays (Custom Text Available)
Brake Res Cover
Fuse Box Cover
Air Box Cover
Coolant Cover
Washer Cover
Optional Plenum Cover
Optional Radiator Shroud
Individual covers are available here. http://www.rpidesigns.com/shop/categ...d-accessories/
Camaro 6 Forum Members Save With Code PHIL5 At Checkout
RPI Designs is offline   Reply With Quote
Old 12-16-2018, 10:58 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Use coupon code LANA5 to save 5% off your order!
RPIDon is offline   Reply With Quote
Old 01-01-2020, 08:08 AM   #3
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank you for the orders!
Old 12-16-2020, 10:20 AM   #4
RPIDon
RPIDon's Avatar
Drives: Camaro
Use code RPISHELLEY5 for savings
Old 10-10-2021, 07:45 AM   #5
RPI Designs
