06-10-2012, 11:44 PM | #1 |
Her Name is Mila
Drives: 2012 Camaro 1LT A6, 2014 Camaro 1LS Join Date: May 2012
Straightpipes
Hey everyone,
I haven't had much time on here to post or anything in a little bit but I have a few buddies who say straight pipes will not pass DMV inspection but some of my other friends say they will. Can someone help me out because I am coming closer to getting my Camaro and still haven't decided which exhaust I want I have only narrowed my list down. Thanks |
06-10-2012, 11:48 PM | #2 |
Drives: 2012 2LT/RS 6L50 automatic TF-3 Join Date: Apr 2012
I guess it depends on where you live. If you mean deleting the cats and mufflers it prolly won't pass a true dmv inspection, the cats are a federal requirement.
Its better to burn out , than to fade away.
06-10-2012, 11:58 PM | #3 |
Drives: 2012 LS M6, Black Join Date: May 2009
"Some of your other friends" are delusional. Don't do it.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR 1987 Dodge Raider Turbo Project 1986 Mitsubishi Montero 2.4l FI Transplant |
06-11-2012, 12:03 AM | #4 |
Her Name is Mila
06-11-2012, 12:09 AM | #5 |
Drives: 2010 Camaro 2SS Join Date: Apr 2012
do it, when your passing thru a smaller city that does require emissions get her inspected. hell, sounds like a good enough reason to take a road trip to me
06-11-2012, 12:20 AM | #6 |
Her Name is Mila
06-11-2012, 12:36 AM | #7 |
ask your car buddies, everyone knows some one that will make it "pass". My neighbor will put an inspector stick on a... go cart...
lets not over think the situation here.... straight pipes are the beezneeez |
06-11-2012, 12:44 AM | #8 |
Her Name is Mila
do you have them on your Camaro? Because I have only heard them once and I really want a good solid example to compare my other exhausts to
06-11-2012, 12:53 AM | #9 |
Auto body and paint guy
Drives: 2010 Camaro LS Join Date: Feb 2011
i did a muffler delete and replaced the mufflers with some resonators and used the stock tips.. sounds good and to me and i have ZERO interior drone when im cruising on the highways. the set up cost me like $120.
06-11-2012, 12:56 AM | #10 |
Her Name is Mila
06-11-2012, 12:57 AM | #11 |
no but i can make one this week and ill post it here..
06-11-2012, 10:14 AM | #12 |
Drives: 2012 Camaro LT Join Date: Jan 2007
You need some backpressure to make power. Removing all of it by going to straight pipes will probably cost you a few HP.
06-11-2012, 06:50 PM | #13 |
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC Join Date: Feb 2012
Removing smog stuff may cause problems with warranty and dealer too. I agree also with unkillsam zero back pressure may cause tuning problems and power loss on low end. And the gov't gets shitty when you remove smog equipment if they catch you.
06-12-2012, 10:47 AM | #14 |
Team LFX
Drives: 2012 Camaro LS Join Date: Dec 2011
