04-12-2017, 11:38 AM | #29 |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
Oh what the hell... BC racing monoblock RZ 22, 19×10.5 (offset to be determined) in a dark clear finish:
As Delivered: 2017 Mosaic Black 1LT RS 2.0T | M6 | HD brake and cooling | Bose & 8"screen | Front lip extension | Blade spolier | Black bowties | Painted splash guards
Installed Mods: 25% Window tint | Headlight, side marker and third brake light Phastek tint kit | GM black taillights with Gen5diy LED harness and bulbs | LED license plate bulbs | Gorilla lug nuts, black | GM 'performance' center caps | RS and sheild badges removed |
04-12-2017, 11:53 AM | #30 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Oh yeah, love those wheels!! Congrats, I know you are having some fun.
Kindness and compassion #OthersFirst |
04-12-2017, 12:00 PM | #31 |
Yah... Kinda putting the cart before the horse here with buying the tires first, but the close out deal on them made it hard to resist
04-12-2017, 02:57 PM | #32 |
Blessed ❤️
Totally get it.
04-13-2017, 10:37 AM | #33 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Lovely looking wheels.
If we used the 1LE/ZL1 wheels as a guide, you'd want a 14mm front offset (to keep distance from the wheel to the strut the same) and 43mm rear (to keep the tire centered in the wheelwell the same).
04-13-2017, 10:43 AM | #34 | |
I'm looking to keep offsets front and rear the same so I can rotate... Was thinking a 35mm offset (only plugged numbers into a 'fitment calculator', haven't been under the car with a tape measure yet.) Any advice on offsets for a square setup? I realize a spacer might be needed up front, also I *think I'll add coilovers to this setup... I'm thinking about holding out for the spool valve ZL1 1LE setup with some different spring rates though also...
04-13-2017, 12:12 PM | #35 |
Hot Dog
Thank you too!
Ok, so with the wheel offsets, it seems the main concern is clearing the strut up front. Just to write it down, the SS 1LE wheels are 20x10 et20 front, and 20x11 et43 rear. To have the same clearance up front with a 10.5" wheel, you need to subtract 1/4" of offset, which means 10.5" wide with an et14. I know glamcem is running a 19x10.5" et22 with a 5mm spacer, making his effectively et17, and he had to grind his struts for clearance. In order to do a rotatable square setup, you'll have to do something like 19x10.5 et44 and then run a 30mm spacer up front. That would work. It would clear the front strut and be within 1mm of the factory SS 1LE in back. Now, if you eventually went with the ZL1 1LE DSSV's (LOL with the acronyms), you'll have more room up front to run a smaller spacer, but we'd have to measure that out when the ZL1 1LE wheel offsets are known.
04-13-2017, 08:13 PM | #36 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Lovin this progression!
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
04-14-2017, 12:42 PM | #37 |
Scale confirms the 27lbs that TireRack claimed
04-16-2017, 01:14 PM | #38 |
Out of winter storage... First thing is a rear diff flush
04-16-2017, 04:23 PM | #39 |
SABIO
UPS delivered your tires!!
OUCH, How much did they get you for? I can only imagine. I used a border service to get my tires and picked them up in Mississauga.
04-16-2017, 07:30 PM | #40 |
Lovin the growl...
Drives: 2018 2SS Join Date: Mar 2017
Exciting journey it sounds like. Good luck hitting those number! And have fun! (wish I had that type of knowledge swimming around in my head)
04-17-2017, 06:40 AM | #41 | |
I'll have to look into these border transport guys... What did you pay to get your tires to Mississauga?
04-17-2017, 06:42 AM | #42 |
Thanks! I hope you have as much fun reading as I do typing it up and taking pics... Reach out on the forum with questions, lots of knowledgeable peeps willing to help out in this community
