01-04-2018, 10:59 AM | #1 |
Drives: ZL1 six speed manual Join Date: Jan 2018
Lingenfelter ZL1
Apologies in advance if this has already been asked, or if there is a better place to ask this (in which case please move).
A buddy of mine owns a stage 2 Lingenfelter ZL1. He has a manual toggle switch installed in the console for controlling the exhaust flaps. He's concerned about engine damage (because he has the stage 2 done to the engine) if he drives the car hard with the exhaust flaps closed, and has asked me to research it for him. Is there any possibility of engine damage when flooring it with closed exhaust flaps? |
01-04-2018, 11:24 AM | #2 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
He is running a 10% lower and 2.55 upper, plus a 629/656 cam, so you are adding tremendous boost with longer value duration and then plugging the exhaust and asking for a part of the CAT to come back in to the Heads because its open longer. Or maybe not |
01-04-2018, 12:39 PM | #3 |
He doesn't have a Mild2wild controller, that's why he's unsure.
The switch appears to be an on-off switch of some sort, rather than a simple F8 cut-off. We haven't yet reverse-engineered how it works or ran tests because the car is in the garage for the Winter. |
01-04-2018, 02:32 PM | #4 |
Drives: 2015 ZL1, Red Hot A6 Join Date: Aug 2016
There is no danger to the engine t run with the flaps closed. Lots of people do it once catless to cut down the noise. Worst case is a slight addition to backpressure and miniscule power loss but likely not noticeable.
2015 Red Hot ZL1, Rotofab, Kooks LT's, 10" lower, ID850's, JMS BAP, BTR stage 3 torque cam, meth injection, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension |
01-04-2018, 03:36 PM | #5 |
Lots of people do it once catless .. That's the Key.. Just sharing what GM warranty is seeing come back in..
01-04-2018, 04:34 PM | #6 |
I ran the 1/4 once with the flaps forced closed by accident. Cost me maybe a full .1 at the most. The increase to the back pressure is minimal.
2013 ZL1 CRT M6
__________________________________________________ ____________________________________ Current Mods: Rotofab CAI, Big Gulp, and Res. ATI Superdamper and 10" Lower, DSX FF Sensor, DSX Aux Fuel Pump, ID850s, Kooks 1 7/8" Headers, Forced Induction Interchiller, McLeod RTX Twin disk. DSX Tuned. Running on 20" MT ET Street SS on stock wheels for the strip. Best 1/4 mile to date:10.81 @130.43 mph w/ 1.61 60' Just added: Jokerz Stage II blower port and FI Interchillers blower lid spacer. |
01-04-2018, 04:46 PM | #7 | |
Sent from my SM-G950W using Tapatalk
01-04-2018, 04:53 PM | #8 | |
01-04-2018, 04:57 PM | #9 | |
01-04-2018, 07:10 PM | #10 |
01-04-2018, 07:40 PM | #11 |
Probably a good idea to call Lingenfelter and ask them what they think.
Its probably not a big deal.
01-04-2018, 09:18 PM | #12 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
Never happen.
Bryan 2018 ZL1 M6
01-05-2018, 08:20 AM | #13 |
That's what I'm afraid of...others might read it and believe it too.
01-05-2018, 08:34 AM | #14 |
