Roto-Fab
Old 08-23-2018, 03:56 PM   #1
oachalon
Drives: 2010 Camaro 1SS
Cradle Bushings vs Hotchkis Chassis Brace
Hi,
I have had a set of BMR rear cradle bushings sitting in a box for the past 4 years. I have been reluctant to change out the bushings because I do not want to do the heat method (garage queen and it bothers me), and i dont trust myself cutting out the bushings or trust a shop around here to do it either. I could make a tool or I see ridetech sells a tool.
Before buying the tool or making one, i wanted to see what everyones thoughts were on changing out the bushings (yeah i know i already have them) vs the Hotchkis Chassis brace they sell that basically adds a brace that connects the rear cradle to the chassis in another spot.
I dont see a lot of people running them on here, but does it correct the issue or should I stop being lazy and just get under the car and get those bushings out and replaced?
2010 1SS/RS LS3 M6
Edelbrock E-Force Supercharger, 3.00" Pulley, Roto-Fab CAI, Stainless Power LT Headers, LPE Dual Fuel Pump, ID850's, Custom Grind Cam, Katzkin Leather/Suede Interior 630RWHP mustang dyno.
oachalon is offline   Reply With Quote
Old 08-23-2018, 04:11 PM   #2
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Replace the bushings. It changes the feeling of the car, and it's much better, especially for a stick car. The heat and press method is no big deal - just did mine. If it makes you feel better just hit them with a little paint after you press them out. I think you've you finally do it you'll be real glad you did - those stock bushings, especially in the 2010-2011s, really suck!
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 08-23-2018, 05:49 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^^ Listen to this guy, he knows what he's talking about!! I am doing mine this Saturday and can't wait to drive the car with them in, going solid with Pegasus bushings. Thanks acammer..
1JEWLDSSRS is online now   Reply With Quote
Old 08-23-2018, 06:27 PM   #4
oachalon
Thanks for the response. I am still not going the heat method. Car has 9800 miles on it, again garage queen. When I do it will probably end up buying that ridetech tool for pulling them out. If anyone has a used one they would like to sell just PM me.
2010 1SS/RS LS3 M6
Old 08-23-2018, 08:58 PM   #5
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I had bmr bushings done in 2017 along with toe links and trailing arms. They are worth it to get rid of wheel hop. Had incerts before I upped the power. Those were noticeable also, bushings finished it off. No wheel hop, but I have keep revs low on start at autocross as no traction now either..lol
VR Baron is offline   Reply With Quote
Old 08-24-2018, 04:54 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Yes I would replace bushings. I put the same brace on my 2010 L99 and my 2013 LS3. Helped allot over just stock. Then when I bought the COMPLETE 1LE track pack that included bushings that really stiffened things up. I have both on my car and work great for the last 4 years.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-24-2018, 08:45 AM   #7
acammer
acammer's Avatar
What is the concern, exactly, with the heat method? Clearly you're not afraid to alter the car, it's got a blower, a cam, etc. You're not heating it to the point where you're melting down the metal, you just need to get it hot enough to release the glues that hold the bushing. If you're worried about the paint, you just hit them with a little paint after you clean them up - they'll be nice and hot and it'll dry instantly.
Old 08-24-2018, 08:55 AM   #8
acammer
acammer's Avatar
For what it's worth, I just did mine, and here is the write-up I completed. It's not a how-to by any means, but it covers the basics, and the more on the results of the install.
https://www.camaro5.com/forums/showthread.php?t=535425
Old 08-24-2018, 09:14 AM   #9
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
I have both. The Hotchkis also helps protect the fuel system when I road race - which is why I kept it. Cradle bushings are what I would do vs Hotchkis.
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 08-24-2018, 08:31 PM   #10
oachalon
I am not concerned about the heat hurting the metal it comes down to the paint. I want to keep the factory coatings/paint on this car as much as possible.
$100 to keep the factory paint still perfect even if it’s on a cradle is worth it to me.
2010 1SS/RS LS3 M6
Old 08-27-2018, 07:56 AM   #11
acammer
acammer's Avatar
To each his own - in you're case you're gonna need a tool for removal then.
Old 09-09-2018, 09:55 PM   #12
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
I have both the Hotchkis chassis brace and Pegasus subframe bushings. The Hotchkis was installed first which made the entire chassis feel much more connected. The triangulation of the Hotchkis brace stiffens the entire car. The Pegasus subframe bushings made the rear end more stable, planted and helped the car hook up really well after my cam install. So, I would say that each of these mods worked differently.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 09-09-2018, 10:39 PM   #13
NEstyle
Drives: Caprice
You can make a bushing removal tool from stuff you have lying around your garage. Minimal heat will get them out. About 300-350 F is all you have to heat the cradle to. No biggie. It did not phase the paint on my cradle. The paint on the cradle looks like crap anyway. You will never notice.
NEstyle is offline   Reply With Quote
Old 03-09-2023, 08:10 PM   #14
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
See, all it takes was a search and finding a 5 year old thread to answer my questions. I have a Hotchkis brace but wondered if it made a difference if I added solid cradle bushings to the mix.
Thanks
FasNuf is offline   Reply With Quote
