04-28-2015, 09:14 PM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Jan 2014
Cannot get ZL1/Z28 brake pedal pad on! Save me a headache.
So I got the ZL1/Z28 brake pedal pad off (which in my research is the hard part.)
I got the gas pedal on, but I cannot get the brake pedal pad on. Suggestions? Tips? |
04-28-2015, 09:16 PM | #2 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
did you get the right one ie. manual vs automatic? automatic brake pedal is the size of a brick while manual is small and delicate like a flower.
04-28-2015, 09:26 PM | #3 |
04-28-2015, 09:30 PM | #4 |
I did my pedal set on a manual and I used a small flat tip and some WD40 I've even read about putting them in the oven for a few minutes to make them a tad more flexible....
04-28-2015, 10:23 PM | #5 |
Drives: 2013 Camaro LFX Join Date: Jan 2013
I used a heat gun to make the rubber more malleable. It's by far the most difficult thing I've done.
2013 1LS Black
Mods MRT V2 Axle Back, Cold Air Inductions Intake, Vitesse Throttle Controller, 20" Voxx SS Wheels Matte Black, Blacked Out Bowtie, Side Markers, Taillight Bezels, Front Bowtie Delete, 1LE Suede Steering Wheel, Shift Knob and boot. 4-Pack Gauge Cluster, Fog Lights |
04-29-2015, 05:13 AM | #6 |
Drives: 2014 Camaro SS Join Date: Sep 2013
Where do I buy a set?!
04-29-2015, 08:20 AM | #7 |
Lifestyle = Deathstyle
Takes a lot of elbow grease. I used soapy water and a large flat head screwdriver. Work the angles...took me about 45 min...lost about 5 pounds from sweating, lol. My side hurt for about 3 days too from leaning against the frame, lol.
11 2SS/RS
05-01-2015, 10:01 AM | #8 |
Drives: 2011 2ss/rs Join Date: Dec 2014
Tool I used that was pretty helpful was a z shaped flathead screw driver. Took my time prying the rubber around the pedal. Alot easier than using a regular flat head.
05-04-2015, 02:55 PM | #9 |
Drives: 2013 VR vert ZL1 Join Date: Aug 2012
I put mine in the oven for a few minutes to soften the rubber up. It was hot as hell and I burnt my thumb but it took me 5 minutes to get it completely on.
Sent from my SM-N900P using Tapatalk |
05-04-2015, 03:18 PM | #10 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
They don't make anything easy with those. The brake pedal itself is made out of Adamantium or something, had to drill through it to put on my Lingenfelter covers and it took forever, broke a couple drill bits, etc.
