dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 06-09-2012, 11:26 PM   #1
se7en
Drives: 10 Procharged SS
How often do you change the oil when drag racing
If you drag race your car every weekend for at least 10 passes with a high HP FI and forged internals.......how often should the oil be changed. Right now i change mine after about 25 passes, but is that too much or too less? Im using Amsoil and Royal purple
se7en is offline   Reply With Quote
Old 06-10-2012, 05:28 AM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I have no idea if that is too much or too less... but I tend to change my oil after 20 or so passes... maybe even fewer depending on the mileage since the last change... car is also a DD...
scrming is offline   Reply With Quote
Old 06-10-2012, 07:04 AM   #3
SC2150
Drives: 2012 Camaro RS, RX supercharged
Good idea to change pretty often when driving hard like that, but I would say you could go twice as long with no worries. I prefer Amsoil to RP though.....
SC2150 is offline   Reply With Quote
Old 06-10-2012, 07:15 AM   #4
jam3
jam3's Avatar
Drives: 2010 camaro ss
Every time I run it. No more than 10 passes for me.
Oil is cheap. Motors and labor are expensive.
I'm sure it's fine to do much more.
I'd rather keep all the insurance I can.
jam3 is offline   Reply With Quote
Old 06-10-2012, 09:47 AM   #5
se7en
Im a big Amsoil fan as well, but RP has came out with some good stuff lately. Expensive but good. Amsoil is all i put in my Camaro
Thank ya for the responses
Old 06-10-2012, 09:56 AM   #6
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Once a year. That's still way more than often enough. I change the filter at least twice a year though, because we cut it apart to check for excess metal.
Edit: My race car is not street legal. Gets about 100 passes a year on it.
Edit2: Stripped the motor down after 8 years and there was zero sign of wear. Not even a hint of a ridge in the cylinder wall, bearings looked brand new.
willhe64 is offline   Reply With Quote
Old 06-10-2012, 03:09 PM   #7
Parag
Drives: 2010 camaro 2SS LS3
the oil will last way longer than your nerves will. I just feel like i need to change it, even though it is always perfectly fresh.
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 06-10-2012, 07:50 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Every 10 passes at the dragstrip.... sounds too early to me.
If I made 10 passes every week I'd change it every 6-8 weeks. But in the interim I'd make sure it was topped off.
If I was road racing at say Road America all weekend, I'd change the oil after a weekend but that's a lot of driving.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 06-10-2012, 09:05 PM   #9
Andy@AMSOIL
Drives: 4 wheels
If using the AMSOIL zrod I would reccomend double the drain intervals. If running 1/4 miles I would reccomend draining every 7-10 passes or 2000 miles if made a few passes with that oil
Andy@AMSOIL is offline   Reply With Quote
Old 06-10-2012, 09:20 PM   #10
Pro Stock John
Writer
Every 7-10 passes, maybe you should specify how quick a car. We for example use Amsoil in a 7.4@195 and we change it every other outing but we make 1700HP. I don't think a high 11 second car should change oil after 7 quarter mile passes.
I can make 7 passes on a Tuesday night in a 12/13 second car, and I should change the oil?
Don't think so.
45 year old drag racer
PROJECT HEAVY CHEVY
Old 06-10-2012, 09:24 PM   #11
THE1chopper
Drives: 2010 Camaro 2SS
while we are on subject... how accurate is the oil life % meter on these machines, or does it just go by miles,or the last time the rest button was changed?
THE1chopper is offline   Reply With Quote
Old 06-11-2012, 09:00 AM   #12
willhe64
willhe64's Avatar
I think it also monitors oil temps too.
Old 06-11-2012, 09:06 AM   #13
se7en
Don't think so.
Right now i change it about every 25-30 passes in an 750+rwhp and TQ car low 10's right now. I make about 10 passes every weekend is what i meant to say. I use AMSOIL 5W30, but one thing to keep in mind is that i make my passes on more 1/8 mile tracks than i do quarters.
Do you thirty is about right?
Old 06-11-2012, 09:07 AM   #14
se7en
[QUOTE=Andy@AMSOIL;5103833]If using the AMSOIL zrod I would reccomend double the drain intervals. If running 1/4 miles I would reccomend draining every 7-10 passes or 2000 miles if made a few passes with that oil
So thats about where im at now with running 1/8 mile and changing every 25-30 passes.
