TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 11-25-2020, 10:53 AM   #1
DroptopZ
I'm your huckleberry...
DroptopZ's Avatar
Drives: '10 2SS/RS, '88 IROC vert
Broke my dome light... little help?
Hi guys! I had a nagging flickering in my LED dome bulb and went to pull it and replace it to see if that was the issue. When I pulled the bulb, the connecter stuck and pulled out the socket where it attaches to the car (pics attached).
I pulled the housing and tried searching. It appears that I may have FUBARED the whole thing. However, I found what I think is the right part to replace just the internals of the dome light. Can anyone confirm if I am on the right track?
Also, I am not good with wiring... so can anyone tell me if then pictured panel is attached with a harness, or if I need to get this professionally done?
Thanks in advance!
'88 IROC-Z vert (14.9 @ 92.3) //
'10 2SS/RS LS3 - 423 RWHP, 418 RWTQ
DroptopZ is offline   Reply With Quote
Old 11-26-2020, 08:28 AM   #2
The Wanderer
Drives: Blaze Red 2014 2SS/RS
Looks to me like
all you need is a new bulb, put the reflector back where it belongs and plug in a new bulb and then the lens. Where is the rocker switch to turn it on/off?
The Wanderer is offline   Reply With Quote
Old 11-27-2020, 11:45 PM   #3
DroptopZ
DroptopZ's Avatar
Originally Posted by The Wanderer View Post
Looks to me like
Thank you... the rocker also came out, but is not broken. I was messing with it to see if a poor connection there was causing the flicker.
I was afraid that the white piece that came out was more than the bulb... was I mistaken? Now I feel like a giant idiot, if so...
Old 11-28-2020, 07:36 AM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
It does appear to be the bulb to me. What type of bulb did you have in there. Take a new one and compare the two to see if all they pieces are parts to the bulb or not.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 11-28-2020, 08:09 AM   #5
DroptopZ
DroptopZ's Avatar
Can anyone please take a picture of the bulb insertion point? The more I look at it. I am convinced that the connecter for the LED board just came apart. I thought I ripped the connection point off of a circuit board or something. I will buy a temp bulb today until I can get an RGB color shift one.
Old 11-28-2020, 03:47 PM   #6
Leo72793
Drives: 2011 2SS/RS
im poretty sure the copper colored tabs are the socket. the two white pieces look like LED parts. pop the reflector back in and the tabs should poke through
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 11-28-2020, 03:50 PM   #7
DroptopZ
DroptopZ's Avatar
Thank you! I feel like the biggest dumb-@$$ but I did the LEDs 10 years ago when my eyes were better. Lol!
Old 11-28-2020, 06:22 PM   #8
DroptopZ
DroptopZ's Avatar
Yep. I win the dumbest thread on the internet for the day. Thanks guys!!
