04-26-2016, 11:17 AM | #1 |
Drives: 14 1SS RS Black (rental) Join Date: Nov 2014
1LT V6 running temperature
My temp hand has never gone past this point. Is this normal? Got it with 12miles it now has 2,800 and never has it gone to the halfway mark. Every other car I've have has stayed at half.
04-26-2016, 11:27 AM | #2 |
I used to be Dragoneye...
My 12 ZL1, and 14 SS were the same. ⅓ or so....
Cycle your DIC to display coolant temperature, and so long as it is showing about 190-200..you're good. |
04-26-2016, 11:59 AM | #3 |
Drives: Just a fan for now Join Date: Apr 2014
Must reach full operating temp engines don't like to run at less that 190-200*F. Condensation needs to be boiled off. So your thermostat is either opening too soon or the sending unit is sending a false reading to the ECU and or gauge.
Have it checked out. |
04-26-2016, 12:49 PM | #4 |
Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
completely normal. Mine is the same.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
04-26-2016, 01:26 PM | #5 |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Put a scan gauge on the car or some other OBD2 reader and get some real numbers. That might not even be a real gauge. It just stays in a "feel good" position and only varies with extremes. I can't tell you how many cars are "Gauged" like this today.
My old GTI always read 190 degrees when the actual temp varied from 155 to 220 or so..
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
04-26-2016, 01:42 PM | #6 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
My V6 M6 is exactly the same way, the DIC will show you what the real temperature is though.
It does bug my OCD a little bit, I wish it ran in the middle of the gauge, but better too cold than too hot! Whiskey |
04-26-2016, 04:55 PM | #7 | |
Drives: 2016 SS Join Date: Jan 2016
DIC on the V6 1LT actually show the coolant temp? my 1ss doesn't even do that. |
04-26-2016, 05:12 PM | #8 | |
Drives: 2017 Camaro 2SS Join Date: Aug 2014
Yes it does, and my gauge stays at that spot too. seems normal to me
2017 2SS Summit White
LT1 A8 NPP |
04-26-2016, 05:58 PM | #9 |
Drives: '16 2LT RS Join Date: May 2009
My 2L is the same, I think you are ok.
2016 2LT/RS, 8A
04-26-2016, 07:08 PM | #10 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
It's fine..... Where the needle is in reference to the real temperature means nothing. Temp gauges are about the least accurate gauge on the dash board. Some cars are calibrated to show right in the middle when at full running temp, others show below half. So long as you're not significantly into the extremes you are fine.
If you were running too cold it would trip the check engine light, as all modern cars have thermostat temp sensors that are actually spot on accurate as the engine temp will affect fuel economy. Running even a few degrees too cool can lower fuel economy, so they now have thermostat temp sensors right at the thermostat and if engine temp goes down even a couple degrees more than it should you will get a check engine light before or instead of a coolant temp light. |
04-26-2016, 07:38 PM | #11 | |
What's more important is to get familiar with the behavior of this needle. In LA your job is a little easier because your ambient temperature will be more uniform throughout the year. Basically the gauge should climb to a certain position within a certain time and stay there unless you let the vehicle cool. Once the engine is warmed up, if the needle fluctuates you likely have a problem with either the gauge itself or the cooling system (thermostat, fans, etc.). |
04-27-2016, 10:20 PM | #12 |
So much good info guys. Much appreciated.
04-27-2016, 10:40 PM | #13 |
Drives: 2016 Camaro 1LT M6 Join Date: Aug 2008
Trust me even if the car hits 260 the needle will barely move. Look at the actual temperature into the DIC.
04-27-2016, 11:32 PM | #14 | |
Whiskey |
