Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Forced Induction - V6
Old 05-19-2014, 02:43 PM   #1
11 camaro
Drives: camaro rs
ported throttle body
has anyone seen any differance on the ported throttle body after install?
11 camaro is offline   Reply With Quote
Old 05-19-2014, 06:06 PM   #2
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
I noticed a quicker throttle responce
Sikoriko is offline   Reply With Quote
Old 05-19-2014, 06:50 PM   #3
11 camaro
Drives: camaro rs
Old 05-20-2014, 07:48 AM   #4
wutshotDJroomba
wutshotDJroomba's Avatar
Drives: 2012 Camaro LS/SC
I agree, it kills the dead spot that occurs when you step on the pedal. Great mod for the money, I'd highly recommend.
"....Empty your mind, be formless. Shapeless, like water. If you put water into a cup, it becomes the cup. You put water into a bottle and it becomes the bottle. You put it in a teapot, it becomes the teapot. Now, water can flow or it can crash. Be water, my friend.”
-Bruce Lee
wutshotDJroomba is offline   Reply With Quote
Old 05-20-2014, 08:03 AM   #5
LBreezie
LBreezie's Avatar
Drives: 2012 Camaro 45th anniversary
Would a ported tb interfere with a turbo setup?
LBreezie is offline   Reply With Quote
Old 05-20-2014, 08:53 AM   #6
mpiersd
mpiersd's Avatar
Drives: ABM #2041
No, it should not. Everything you can do to clean up and smooth out the flow of air helps. Especially in a FI application. Even if it nets only a couple of HP.
And as always, YMMV.
Retired United States Army
Bernadette: 2LT/RS, ABM #2041 of 3903
ZL-1 Springs | CAI | Muffler delete | Magnaflow resonator | LED DRL | DRL harness | RX Catch Can | Mini me
Cortana: 2015 Harley Davidson Road Glide Special
V&H Power Duals Headers & Oversized 450 Raider mufflers | Screamin' Eagle Stage 1 Chisel Extreme intake | Screamin' Eagle Stage 1 programmer | Klock Werks 12" Pro-Touring windscreen
Own an Aqua Blue Metallic Camaro?
Click here to join us on Facebook and help us in establishing the Aqua Blue Registry to locate all 3903 of these beautiful Camaros!
mpiersd is offline   Reply With Quote
Old 05-20-2014, 09:00 AM   #7
LBreezie
LBreezie's Avatar
Thanks for the info, definitely my next mod
Old 05-20-2014, 02:45 PM   #8
11 camaro
Drives: camaro rs
thank you
