11-13-2016, 10:26 PM | #1 |
Oil cooler block off
Ok so during break in for the first couple hundred miles I'm going to block off my oil cooler.
Do I completely block off both holes or do I get one what let's oil pass from one hole to the next?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
11-13-2016, 10:54 PM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I haven't ran the factory oil heater....I mean cooler in almost 2 years.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
11-14-2016, 12:51 AM | #3 |
Do you run anything at all? I was looking at running an external after engine break-in.
11-14-2016, 02:13 AM | #4 |
I don't run a cooler of any sort.
11-14-2016, 03:59 AM | #5 |
What block off do you run? Not afraid of running the oil to hot? I know in a pull I would see 235-240* on oil temp.
11-14-2016, 08:08 AM | #6 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
I would say those TT's will heat your oil a bit more than what Bo is running.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
11-14-2016, 08:16 AM | #7 |
Drives: 2006 Z06 Join Date: Oct 2010
Zero cooler here too. Factory block off.
240-250 is GREAT oil temps. That is where you want it.
Nick
Corvette Z06 -1200ish rwhp |
11-14-2016, 08:28 AM | #8 |
Ya 250 sounds nice. To bad the gauge stops at 270 lol
11-14-2016, 09:05 AM | #9 |
Drives: 2010 Camaro SS/RS CGM Join Date: Dec 2011
I got the plug and the oil cooler block off if you want to buy them from me. I will sell pretty cheap. Let me know. I too had no cooler, but now that I want to race I wanted one. only thing you will need is the 2012+ radiator upper hose.
11-14-2016, 10:59 AM | #10 |
My 6.0 don't accept the 6.2 oem oil cooler. That's why I'm switching to a different one. With my power I'm going for I'm going to want a oil cooler
11-14-2016, 01:38 PM | #11 |
Oil protects better when hot. 220-250 is great oil temps.
It doesn't depend as much on power as application. If it is just a straight line car, I seriously doubt you need a cooler and it may cause more harm than good. If it is a road race car that sees 10-30 minutes of solid on it, that is when oil coolers are needed. A single 1/4, 1/2 or 1 mile pull does not need an oil cooler.
Nick
11-14-2016, 03:25 PM | #12 |
Drives: 2010 Chevrolet Camaro 2SS/RS Join Date: Dec 2015
I removed my oil cooler this spring, my oil temps never got over 230 even sitting in stop and go traffic, in fact it's never read hotter than with cooler on the car
2014 Sierra Denali 6.2 ... Daily Driver
2012 Camaro ZL1... m6 stock toy 1999 Trans Am... Waiting for a new heart |
11-14-2016, 05:19 PM | #13 | |
11-14-2016, 07:13 PM | #14 |
