Old 06-25-2016, 04:32 PM   #1
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Best brake pads for track use?
My brake pads are absolutely gone and I'm looking for new pads that are good for both street and track. Should I go aftermarket? What would you guys suggest
SynergyGreenSS is offline   Reply With Quote
Old 06-25-2016, 05:11 PM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
How often and how aggressively do you road course your 11?
JusticePete is offline   Reply With Quote
Old 06-25-2016, 05:13 PM   #3
SynergyGreenSS
Drives: 2011 2SS
Well yesterday was the first time but I'm 100% for sure taking it to the track again. As yesterday was my first time, I wasn't being super aggressive but I'm sure I'll be more aggressive next time. I daily drive the car though so I still need them to be good for daily use
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
Old 06-25-2016, 05:46 PM   #4
JusticePete
I would suggest two sets of pads. OE fro street use and with Hawk DTC 70 front and DTC 60 rear or CobaltFriction XR1 front and XR3 rear. Both are excellent track pads that will stand up t the abuse of a well driven 5th Gen.
You should also fully flush your brake and clutch fluid switching over to SRF. SRF is the gold standard for track use because the wet boil with SRF is higher than most other bands dry boil. SRF is lso the mot expensive t tart with, but because the wet boil is so high, it does not need t be completely changed out and over time the cost evens out.
These is a lot more you want t do as you get involved in road course / HPDE activities, but stopping is always more important than being fast. Let me know how can help as you grow into your new addiction.
Old 06-25-2016, 06:18 PM   #5
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Yep, nothing like coming into a corner and the brakes going mushy...
I destroyed my zl1 brake pads ... Went to hawk 60s ... Defiantly don't street them ... Loud and whiney... Took a lot of silicon grease and the backing plates from my stock rears... To get them quiet, grease turned to ash after one session
http://s221.photobucket.com/user/JBo...nyov4.mp4.html
Crash76 is offline   Reply With Quote
Old 06-25-2016, 06:58 PM   #6
JusticePete
Embrace the squeal, the sound of real brakes.
Old 06-26-2016, 01:29 AM   #7
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
I run HT-10s now but Pete you mentioned to me to rum DTC-70s all round. 135+ mph stopping on the track I favor on the main straight.
L99CAMA2011 is offline   Reply With Quote
Old 06-26-2016, 01:35 AM   #8
White_SS/RS
White_SS/RS's Avatar
Drives: 14 1LE
+1
LMS Engineering
White_SS/RS is offline   Reply With Quote
Old 06-26-2016, 09:35 AM   #9
JusticePete
I have a number of people running 70s front and rear. Some prefer a split. Some find the 70s all round too aggressive and upset the bias while others do not. Brake system, driving style, tires, setup and more factor in this.
Old 06-29-2016, 03:48 PM   #10
naikaidriver
Drives: 2010 Camaro 2SS/RS
I hadn't considered the 70/60 setup for the Hawks but that makes perfect sense as the rear can get pretty light under really hard braking and downright scary sometimes when trail braking during corner entry!
BTW! If you don't want to change your pads before and after every track day, IMHO, the Hawk Plus pads aren't too bad but are really dusty. Stay away from the StopTech street/track pads. The StopTechs are as noisy and squealy as race pads but will cook like stock pads.
Scott
naikaidriver is offline   Reply With Quote
Old 07-20-2016, 10:02 AM   #11
RacerBX1
Drives: 2011 Camaro SS R/S
What is the correct part number for the Hawk HTC-70 front pads on a 2011 Camaro SS. Hawks website is saying HB726U.582, but Phastek Performance is saying HB453U.585 . I plan on ordering some, but don't want to get the wrong part and play that game. Thanks in advance. Also if anyone can confirm HTC-60 for the rear that would be great as well. Is HB194G.570 correct?
RacerBX1 is offline   Reply With Quote
Old 07-20-2016, 10:07 AM   #12
JusticePete
Per the HAWK website for a 2011 SS
DTC-70
Front Brake Pad
Pad Description:
- High temperature & high torque - Provide superior pad and rotor wear - Excellent torque control - Excellent modulation and release characteristics - Designed for high deceleration rates
Part#: HB726U.582
$389.48
Old 07-20-2016, 01:43 PM   #13
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
i like 70/60 for stock calipers and 70/70 for my current setup with the 6 piston fronts. i just rebuilt my front calipers (seals only not new pistons) the piston seals were still in good shape but the outer dust seals were toasted. i made some backing plates for the big front pads to help save the dust seals.
ive got a friend pushing these new pads on me. he is sponsored by them so he is biased a lil. Pete, and others, what do you guys know about Pagid brand brake pads? ive went around the world on brakes and my setup now works great so i dont want to change anything. he is wearing me out about how awesome these pads are.
JOHNSONROD is offline   Reply With Quote
Old 07-22-2016, 11:26 AM   #14
SPCBA
Drives: pleather and Chiclets
Pagid is rebranded from another company. German if that makes you feel better.
Google textar if you want more reviews
SPCBA is offline   Reply With Quote
