TireRack
Old 03-18-2022, 09:20 PM   #1
SSVictor
Drives: 2010 Camaro 2SS
Help car won’t turn on after torque converter
I just got a 3000 stall converter installed and it was running fine when I got it after 1 hour of driving a engine light came on with abs and stability track and all my gauges also stopped working. My car wouldn’t shift out of 1st gear. Whenever I looked at the engine light on my SCT Tuner it said General Error 21000. Now my car won’t crank at all.
SSVictor is offline   Reply With Quote
Old 03-18-2022, 10:14 PM   #2
SSVictor
Update now when I try to crank it it acts like the battery is dead but all the gauges and everything work perfectly fine and the battery isn’t bad.
Old 03-18-2022, 10:24 PM   #3
HDRDTD
Are you still using the original battery ?
Old 03-18-2022, 10:27 PM   #4
SSVictor
Yes it’s the original battery
Old 03-19-2022, 06:29 AM   #5
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
It's way past time for a new one
joshnmn is offline   Reply With Quote
Old 03-19-2022, 07:53 AM   #6
Brutale arancia
Brutale arancia's Avatar
Drives: 2013 ZL1 Camaro
Reminds me of the time I let a wire get pinched between the block and bellhousing.
Brutale arancia is offline   Reply With Quote
Old 03-19-2022, 08:50 AM   #7
HDRDTD
Yes indeed it's time for a new battery regardless of how you have determined that your battery is 'ggod'.
With age and all the electronic stuff in our cars, when a battery ages, they cause all sorts of strange things happening.
Old 03-19-2022, 11:52 AM   #8
ADVMax
Sporting Foole
ADVMax's Avatar
Drives: 2010 Camaro SS
Have a load test done on the battery. Mine was still cranking the car fine but I had some of the “time for a battery” indicators. These cars will tell you when you need to freshen up the battery. A load test tells it all, mine went flat about the time he hit the switch on the load tester.
ADVMax is offline   Reply With Quote
Old 03-19-2022, 01:15 PM   #9
SSVictor
The battery is 70 percent charged
Old 03-19-2022, 01:23 PM   #10
SS376
SS376's Avatar
Drives: 2013 1SS LS3
I'd throw a new battery in. Even if that isn't the problem you need one anyway.
SS376 is offline   Reply With Quote
Old 03-19-2022, 02:46 PM   #11
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
For peace of mind, and most likely to fix your problems, get a new battery. Lots of members here with issues like yours and it solved their problems. Mine worked fine up until the day it died. Was at a buddies shop, had to move my car for a customer. Back out onto the street and installed it, I know I know, car would not start. Battery went completely flat. In my buddies 40 years of owning a shop he has never seen a battery take a sudden hit like that. Luckily I was at the shop, would not wanted to get stranded.
HOJO is offline   Reply With Quote
Old 03-19-2022, 04:24 PM   #12
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Battery voltage isn't a good indicator of a batteries capacity.
FasNuf is offline   Reply With Quote
Old 03-19-2022, 06:17 PM   #13
romcjr
romcjr's Avatar
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99
I'd listen to these guys about the new battery . I've only been here a short time , but I can't tell you how many threads I've seen with exactly the same symptoms and a new battery fixed it !!!
2014 2SS/RS AGM L99
CAI Intake
ELITE Catch Can
POWERSTOP Brakes (5/31/21)
romcjr is offline   Reply With Quote
Old 03-19-2022, 06:41 PM   #14
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Most likely the battery but a poor ground can cause this too. Regardless it's time for a new battery anyway.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
cam, engine light, help me, torque converter
