Old 03-18-2021, 08:20 PM   #1
Kemo Savy
Drives: Make it a 6 speed in SS trim.
SS Alignment Specs
Each time I get an alignment they keep saying these specs are legit. I see a lot of red that makes me uncomfortable. A I right or are they right? 17' SS with Dual mode FE suspension.
Kemo Savy is offline   Reply With Quote
Old 03-18-2021, 09:14 PM   #2
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
The specs are here for a standard SS(not SS 1LE): https://www.camaro6.com/forums/showthread.php?t=443693
Your front cambers are a bit too aggressive(negative) and that's about it. The caster is non-adjustable so whatever you have is what you will be stuck with.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 03-18-2021, 09:22 PM   #3
Kemo Savy
Will this cause tire wear?
Old 03-18-2021, 10:45 PM   #4
UnknownJinX
It's mostly toe that will increase tire wear, not camber(unless you have those ridiculous ricer camber specs). It might tramline more with more camber.
Current:
Past:
Old 03-19-2021, 01:32 AM   #5
ex-SS-ve
ex-SS-ve's Avatar
I find the sweet spot at zero toe and .5 degrees of camber. Ive done this on all my cars for many years and have zero tire wear issues and the handling remains spot on.
ex-SS-ve is offline   Reply With Quote
Old 03-19-2021, 10:03 AM   #6
Hotwheeltat
Drives: 2020 Camaro SS 1LE
That’s a shit alignment right there. Nothing is equal left to right. Whoever did it is lazy.
Hotwheeltat is offline   Reply With Quote
Old 03-19-2021, 07:57 PM   #7
Kemo Savy
Will it cause a problem with tire wear. Handling is still good as always.
Old 03-19-2021, 08:40 PM   #8
Hotwheeltat
Excess tire wear? Probably not right away. It could be better
Old 03-20-2021, 12:11 AM   #9
Kemo Savy
Do you think I should take it back?
Old 03-20-2021, 01:20 PM   #10
Hotwheeltat
Did you pay for a service? I do my own work and have 30 years working in a shop. I’d never give a customer their car or truck with those alignment specs. Tell them to do it right or give you back your money.
