dave@hennessey
Old 11-25-2013, 05:18 PM   #1
DarkObsession
Drives: 2011 Camaro SS2/LS3
Stock LS3 Exhaust... how restrictive?
I tried a search but... yeah
I want to do some really minor, bolts ons to my LS3 in the near future. I'm thinking CAI, maybe catch can, etc. Nothing that requires a tune and stuff that I can easily take back to stock when I want to.
Problem is since I want to be able to go back to stock easily, I really don't want to touch the exhaust. So the question is, is the stock LS3 exhaust that restrictive? I race this car but again, I'm not looking for 11s or anything. I'd like to be able to easily hit 12s in the car (and I'm basically there with a better launch if you look at my sig) so I don't need a ton of power.
Opinions?
Thanks guys!
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Old 11-25-2013, 05:30 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Stock exhaust isn't restrictive, just ugly and heavy. That being said, I won't be switching mine out from stock anytime soon. Get some high-flow cats and it'll open up the sound a lot.
shibbs is offline   Reply With Quote
Old 11-25-2013, 05:33 PM   #3
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
From the cats back, not restrictive at all. The cats are most of the restriction.
Go with Solo high flow cats. No tune necessary, sound will improve immensely, and you will notice a performance increase.
Best bang-for-the-buck mod ever.
Iron Lung Jimmy is offline   Reply With Quote
Old 11-25-2013, 06:09 PM   #4
F-16 Camaro
Drives: 2010 Camaro 2SS Black
What size is the inlet/exhaust of the stock cat?
Will a 3" HF Cat fit without much cutting/reducing?
F-16 Camaro is offline   Reply With Quote
Old 11-25-2013, 06:11 PM   #5
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
I believe the stock system is a 2.5"...
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 11-25-2013, 06:22 PM   #6
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
No its not. The cat back(after the cats) are 2.5" I believe but the factory cats inlet is tiny. I might have a pic still saved on my computer from when I measured and took pics. Hold on a sec I will try to find them.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 11-25-2013, 06:27 PM   #7
VADER SS L99
Name:  cat inlet.jpg
As you can see its only about 2". You might not be able to tell in the pic but the inside diameter of the pipe actually reduces to about 1.8-1.9" further into the pipe. This is one reason people are able to gain 15RWHP from high flow cats alone without a tune.
Old 11-25-2013, 06:31 PM   #8
VADER SS L99
If your getting high flow cats only without doing long tube headers your going to want to just get the direct fit SOLO or JBA high flow cats which are 2.5". Your not going to make anymore power with a 3" cat over a 2.5".
Old 11-25-2013, 07:14 PM   #9
GlennP
Drives: 2011 Camaro 2SS
More restrictive than straight pipes, I know that much >
GlennP is offline   Reply With Quote
Old 11-25-2013, 08:11 PM   #10
Angry Irish
Angry Irish's Avatar
Drives: 2010 Inferno Orange SS/RS LS3
What he said.... Solos all day long. Best mod I've done.
2010 SS/RS LS3 STOCK (for now...)
Angry Irish is offline   Reply With Quote
Old 11-25-2013, 08:27 PM   #11
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Only once you pass 500rwhp is when the stock cat back becomes a real restriction.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 11-25-2013, 08:39 PM   #12
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
what bo said. with a better muffler and x 2.5" will take u to 600...but u will leave a tad on the table, I know I am...but I have zero drone on the interstate, nice trade off.
-John S.
grocerygetter is offline   Reply With Quote
Old 11-25-2013, 08:51 PM   #13
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
We actually found this out on a members car infernometallicss. He has long tubes, cold air, our cam (big) milled heads, circle d stall and at the time of test that was it. He has the no weeds cutouts w/ stock cat-back including the middle resonator. So we dyno'd it cutouts open and closed and it made roughly 30 more rwhp with them open! Now on a bolt on only car i don't think it's going to be that much at all, but start really moving some air and it does become a restriction for sure!
Joe@CPR.com is offline   Reply With Quote
Old 11-25-2013, 09:11 PM   #14
VADER SS L99
That is very surprising. Did it have the stock L99 mid section resonator? Did the car ever come off the dyno for the test? As in was it a back to back test? I read about a LOSS in power from cutouts open on a LS3 car that had full bolt ons(and I do mean full bolt ons with aftermarket cat back). Same car got a Magnuson 2300 and showed a 10RWHP/10RWTQ gain with cutouts open at around the 550RWHP point.
30RWHP is huge. Sure would throw a wrench into the debate on weather the stock cat back is holding power back under 500RWHP.
