Old 11-24-2013, 12:51 PM   #1
aj2ssrs
Drives: IOM 2SS/RS
Intake manifold, heat soak and performance question
Recently a couple threads were started and heat soak was a concern. The first thread was about Nelson Racing's X ram intake and people being worried about a huge metal intake and heat soak issues. The second thread was for a heat shield to help with heat transfer from the block to the manifold. I don't understand how heat soak at the intake manifold causes a loss of performance. Isn't timing pulled when coolant temps rise beyond a certain temp or if the MAF sensor senses high IAT's?
ADM race intake, Dynatech lt headers w/hi-flo cats, Jannetty Racing dyno tune, VMax CNC ported TB, MGW short throw shifter, Elite Engineering catch can
aj2ssrs is offline   Reply With Quote
Old 11-24-2013, 03:27 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Correct, timing will be pulled for higher engine temp, and or for higher iat. This timing pull is what hurts performance.
Rhino79 is offline   Reply With Quote
Old 11-24-2013, 04:16 PM   #3
aj2ssrs
Drives: IOM 2SS/RS
So how does heat soak of the manifold hurt performance? IAT's are measured at the MAF located upstream of the manifold and engine temp is internal engine coolant temp. So say I'm sitting at a traffic light. I have an ADM race intake so the MAF sensor is located in the airbox way upstream of the manifold. MAF sensor is reading the IATs at 80 degrees and coolant temps are up to 195. MAF sensor adjusts air/fuel ratio for 80 degree intake temps but at the same time the metal manifold is getting heat soaked. If there is no sensor on the intake manifold itself, how does the heat soak effect performance? Just trying to figure out if the concerns of intake manifolds getting heat soaked are warranted.
Old 11-24-2013, 06:32 PM   #4
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I'm no expert but just because a sensor is not picking up the hot air does no mean you won't get less performance. I would think you will get KR from the hot air and that's bad either way you look at it.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 11-24-2013, 09:19 PM   #5
OVRKILL
OVRKILL's Avatar
Drives: 01SS
Making claims of power loss due to "heat soak" is pure speculation based on theory. Not saying it doesn't exist, but the only way to validate this phenomena is to have the intake in each material (plastic and alum) tested side by side, same car, same conditions, etc. Can't imagine that happening unless NRE ponies up the tooling money to mold one. Even then, I wouldn't believe anything over a single digit loss. If it were me and this intake showed sizable gains justifying the swap and actually valued this "theory", I might consider a ceramic coating. Lots of fast cars out there running aluminum intakes juuuuuust fine.
I'd focus on what the intake allows to improve downstream instead of worrying about air that might be a few degrees warmer prior to combustion, e.g., cams, heads, etc.
'01SS - RHS 460....fed by 8 little throttle bodies
Kinsler / Fikse / RHS / Mast / MWC / Kooks
OVRKILL is offline   Reply With Quote
Old 11-24-2013, 11:49 PM   #6
JEFF75645
Drives: his wife crazy buying mods
Ive asked this before and never got a clear answer.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 11-25-2013, 05:00 AM   #7
BlaqWhole
Drives: 2017 Camaro ZL1 A10
OVRKILL and Vader both gave some really decent answers to help you out. You have to remember, the warmer or hotter the intake manifold is, well then the more it will warm or heat the incoming air. For optimal engine performance, you want a warm engine with cold air going through it. Hotter air may cause timing to be pulled or fuel to be dumped to prevent engine damage. This all causes a loss of performance. How much heat, how much timing, how much fuel, and how much hp? Well like said before there would need to be extensive testing to know for sure. Most guys who have dyno shops can give you more detailed information. But basically, hotter air, less timing, more fuel dumped, less power. Ever notice that your car is a bit faster in 35 degree weather than it is in 95 degree weather? Cold air man.
Old 11-25-2013, 07:41 AM   #8
JEFF75645
Hey Blaq thanks for the response. My question was geared toward something else. I totally mis read the post. My comment was geared more toward maf in the air box.
Old 11-25-2013, 08:01 AM   #9
aj2ssrs
Drives: IOM 2SS/RS
I understand the effects of air temps and performance and you're 100% right about colder air temps. In 95 degree air you take a hit in performance due to less dense air and the air/fuel ratio adjusting accordingly. My point though is take that 35 degree air temp which is measured by the MAF sensor which in turn adjusts air/fuel ratio for that temp, than heat that air up due to heat soak downstream of the sensor (in this case a huge metal intake manifold) and how does it effect performance. I think what OVRKILL says is true in that it's just speculation as to what happens performance wise. Maybe Nelson Racing could chime in. Thanks for the responses and keep them coming.
Old 11-25-2013, 11:41 AM   #10
DarkObsession
Drives: 2011 Camaro SS2/LS3
To expound a bit on what BlaqWhole said, power isn't simply a function of the MAF/IAT sensors telling the computer what do.
Let's say we have the best CAI possible on the car. Temps going to the IAT are exactly what they are outside (say, 60 degrees).
The computer will read the MAF and the IAT and dump the appropriate amount of fuel to compensate for the air coming in.
However, if the intake is heat soaked, that incoming air will heat up a LOT before it hits the cylinder. Because the incoming air is so hot, the computer will detect pre-detonation (knock) and pull timing to save the engine.
In other words, yes, colder air gives you more power but if you are heating it up a ton anyway, the computer will pull timing resulting in less power.
In my old L67, the M90 Blower on that thing was basically a heat pump. Since GM didn't put a stock intercooler on those, the incoming air - regardless of how cold it was outside - would heat up a LOT resulting in relatively less power. Obviously, the colder it was outside the better since compressing cold air was better than hot air and obviously a supercharger was going to make more power than N/A on that engine but you get the point, I hope
So yes, it is hard to say exactly how much HP you lose due to heat soak without testing but you definitely will lose some.
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Old 11-25-2013, 12:29 PM   #11
aj2ssrs
Drives: IOM 2SS/RS
Thanks DarkObsession. Good explanation. Highlighted in red was the part I was missing. Makes sense that that's where timing is being pulled.
Old 11-25-2013, 01:22 PM   #12
BlaqWhole
Excellent explanation man. Thanks! I also believe the ECU uses coolant temps as a way of adjusting the air/fuel ratios. But I could be mistaken. I know that some older cars had two coolant temp sensors. One was a sensor that reported back to the gauge in the car while the other one reported to the ECU. Some cars had just one sensor that did both of those functions. If I'm not mistaken, cars still have a sensor that reads coolant temps and uses that info in the tuning. Again, I could be dead wrong. But it makes sense.
