02-03-2017, 07:12 AM | #1 |
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
Adding the 24 color spectrum lighting to the 1SS radio
I am doing a DIY for the work around on the 1SS if you upgraded to the interior spectrum lighting. The kit comes with the door spectrum lighting and the footwell lighting. after installing and the dealership flashing the BCM and HMI it still does not give us control of the radio LED light bar on the top so it stays white. The doors and footwell lighting can be changed by driver mode or from the radio touchscreen like the 2SS. The reason the radio does not change is because it has a single white LED installed on the 1SS instead of the multi color as the 2SS came with. So to work around this you can either use your footwell lighting kit that is in the kit and replace the LED boards in the back of the radio or buy a extra footwell light kit like I did and replace the LED boards with it and run the wiring (T-tap) into your already installed footwell lighting kit to be able to change colors on the top of the radio as well just like the 2SS.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
02-03-2017, 07:13 AM | #2 |
Here is the extra footwell lighting kit I purchased for this mod.
02-03-2017, 07:18 AM | #3 |
Radio uninstall. Pop the bottom faceplate off with you hand by getting your fingernail in between the 2 pieces at the bottom and pull out. After the plate is off remove the 2 screws holding the radio in place and swing the radio up from the bottom to remove. You need to disconnect 6 connectors all together from the back of the radio.
02-03-2017, 08:33 AM | #4 |
Now it is time to take the radio apart and replace the LED boards. Take all silver screws out and pay attention where they go because there are 3 shorter screws that need to go back in the hole they came out of. After all screws are out separate the front and back of the radio. Take a small screwdriver and separate the tabs from the footwell lighting pods and the radio lighting pods that hold the boards in place (be careful not to break or damage the pods or the light bars in the radio because they are flimsy). After all pods are open gently replace each single LED board with the multi LED boards. Once installed with the light chip facing inward close the pod back gently till all 4 tabs snap into place. You are now ready to place the light bar back in place and reinstall the radio back and secure with all screws that were removed. The radio part is done now and just time for the wiring portion to get power to these new multi LED boards you just installed in your 1SS radio.
02-03-2017, 11:25 AM | #5 |
Car Enthusiast
Drives: 2017 Camaro SS FIFTY Join Date: Jul 2016
Nice, well done. I love when forum members create post like this one to help others.
I'm wondering if we can change the two white background LEDs behind the radio monitor for two Spectrum Lighting LED. Thank you Hyper.
2017 SS Camaro FIFTY
6MT, Nav, NPP, Black Bowties, Mishimoto OCC, Skip Shift Eliminator, GM Footwell Lighting, NGM Splash Guards, GM Blackout Tail Lights (SOLD) Last edited by Mr. Grumpy; 02-03-2017 at 11:52 AM. |
02-03-2017, 12:44 PM | #6 |
Drives: 2016 SS Convertible Hyper Blue Join Date: Apr 2016
Very cool write up thank you.
Blacked bow ties, full bigwormgraphix blackout
Gm splash guards Mishimoto catch can Black hash marks Curb alert Vitesse controller Jl audio HD 900/5 amp c5 650 components c2 650x coaxials rear fill 2 x 8" W3v3 subwoofers custom ported box Fix 82 module BF TPNS BF Wet Diamond BF Crystal Seal Hydr02 303 Aerospace top protectant |
02-03-2017, 02:47 PM | #7 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
Thanks for doing this DIY for everyone. I'm not to good at making a DIY post . Very good job and great pics.
02-03-2017, 02:55 PM | #8 |
Glad to help!!
02-03-2017, 02:56 PM | #9 |
02-03-2017, 02:57 PM | #10 |
Your welcome. I have a friend trying to find me the right connectors so I don't have to cut anything.
02-04-2017, 06:32 AM | #11 |
I found the factory radio connector for correct fit.
TE CONNECTIVITY (TE) 3W MQS RCPT HSG POSI MATE MQS 953697-2 TE Internal Number: 953697-2
02-05-2017, 06:48 AM | #12 |
Can't wait to get my OEM connectors so I can finish this mod.
02-05-2017, 08:35 AM | #13 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
Great write up and Thank you for doing this for the Camaro family...
2018 ZL1 Convertible A10 @ Kooks R&D. |
02-13-2017, 07:18 PM | #14 |
Got my connectors and terminals in the mail today from TE that Ofer ordered for me at Gen5diy. These are the OEM connectors and terminals that connect to the LED light bars in the radio. I have to switch these out with the smaller black 3 wire connectors and terminals from the footwell lighting wire kit. Will try to get this done tomorrow and get everything wired and running by the weekend.
