10-12-2017, 06:07 AM | #1 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Sep 2014
Car Level for Diff Fluid Change?
I have a 2018 1SS 1LE I am getting ready to change the differential fluid on and want to confirm if the car needs to be level to get the correct amount when refilling. My past cars I had level for the fluid change but with the jack points not being as easy to deal with on this car I want to confirm.
Thanks! |
10-12-2017, 07:10 AM | #2 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
I put mine on ramps front and rear
10-12-2017, 09:29 AM | #3 |
Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
I did my diff fluid yesterday. Had both front and back on jack stands approximately leveled. about 1.1QT came out and 1.2 QT went in.looking at the placement of Drain and fill plugs, an approximate level should be fine IMO.
If you are a Jack and Jack Stand person, I recommend investing in the ZL1 Addons Jack points and Jacking adaptor. It is very comfortable and useful in not hurting the pinchweld or the rocker panel by accident. Thanks, Suresh
2016 1LT RS Summit White M6 10/2/2016 - 3 Miles on ODO - Delivered 11/1/2016 - All around light Black out kit from Phastek 11/15/2016 - OEM Splash guards and all weather mats from ShopChevyParts.com 12/16/16 - 977 Miles. Borla S-type Axleback Planned - CAI Injen, hood wrap, Sema rocker stripes, Sema trunk balckout, Caliper Paint, Reverse LED |
10-12-2017, 12:27 PM | #4 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
my car wasnt level, just the rear end was raised. still got 1.2 out, and it took just over 1.2 to start spilling from the fill plug.
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
10-12-2017, 02:37 PM | #5 |
I have Race Ramps, 2 floor jacks and many jack stands but I don't trust my jack stands on the pinch welds. Yes, I need to get the ZL1 Addons lift points!
Sounds like it may not matter if I'm level or only have the rear raised as long as I get the correct amount back in. For simplicity sake I may just raise the rear which is easiest for me right now and while it's draining put the rear back down to make sure I get most of the old stuff out. |
10-19-2017, 09:18 AM | #6 |
I didnt...I just backed mine up on ramps. 1.2 out, 1.2 in.
2016 NFG 1SS A8
11-09-2017, 11:41 AM | #7 |
Drives: 2018 1LS 1LE Join Date: Jun 2017
I just drove up onto 2x8s (all 4 wheels) and that got me enough clearance to just crawl under the car and do the diff oil change.
2018 Garnet Red 1LS 1LE V6 w/Tech
1100 - 07/26/2017 | 4300 - 09/15/2017 at rail yard 3000 - 08/16/2017 | 4200 - 09/18/2017 shipped! 3100 - 08/19/2017 TPW 09/11/2017 | 4800 - 09/20/2017 train journey done 3400 - 08/25/2017 | 5000 - 09/22/2017 at the dealer, and picked up! 4300 - 09/12/2017 Built! VIN available 4B00 - 09/14/2017 move to rail yard |
