06-26-2017, 01:14 PM | #29 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
I had the dealer do the first one, they let me get under the car when it was jacked up. I checked the oil level before they left and they used Mobil 1 5w30. I will change my own down the road like I have my whole life.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
06-26-2017, 01:19 PM | #30 |
Retired from Car mfrs....
06-26-2017, 03:41 PM | #31 |
Drives: 2017 Summit White 1SS Join Date: May 2017
Yeah, I have had Fumoto valves in previous cars. Very handy. It would prob take a couple days for it to drain 10 quarts though!
06-26-2017, 04:10 PM | #32 | |
https://www.stahlbus-us.com/oil-drai...20plug%20valve |
09-28-2017, 05:53 PM | #33 |
Drives: 2017 1LT RS V6 A8, 2020 Fusion Join Date: Jun 2017
I used a Fumoto Valve on my WRX. I liked it a lot, except for the fact that, having longer threads than the stock drain plug, it extended further into the pan, causing some (more) oil to remain in the pan as it was below the threads sticking up from the valve. I should say, the valve extends further than the threaded part of the oil pan. I would assume the same for the stahlbus drain valve as well. I like the simplicity of the Fumoto valve.
09-28-2017, 06:55 PM | #34 | |
10-02-2017, 08:06 AM | #35 |
Drives: 2017 Camaro 2SS Convertible Join Date: Sep 2017
Getting ready to do my first oil change. 1000 miles. Ain't no way I'm letting anyone else do it. It's not just the dealerships. It's getting harder to find people that like to do a good job and respect other peoples property. No one is touching this baby but me, unless I can't do it. Then they have to let me watch or I will take my money elsewhere.
10-22-2017, 08:50 AM | #36 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
"Nobody cares the way I do..." |
10-27-2017, 03:45 PM | #37 |
Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
Do it yourself.
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
10-31-2017, 10:36 AM | #38 |
Drives: 2018 HBM SS 1LE Join Date: Jun 2017
For anyone coming along reading this later, I thought I'd mention that even though Fumoto says on their website that the Camaro SS may require an extension, I found that not to be the case. There is plenty of clearance for the regular F-107N. Just did my first oil change over the weekend and installed the valve, I'm glad I only have to unscrew the OE plug one time . Hard not to get a little messy when taking out that plug with 10 quarts of oil behind it...
I considered the Stahlbus but honestly, the ball valve design of the Fumoto gives me warmer fuzzier feelings and in all the cars I've used these on, I've never had so much as a single drop of leak ever. I feel especially safe on the Camaro because the valve points sideways and anything that might come along and try to take it off would have to take off most of the bottom of the car first. |
11-06-2017, 12:53 AM | #39 |
Drives: 600whp 2016 C63 AMG/ 2018 SS 1LE Join Date: Apr 2017
I was just wondering if they make a magnetic version of the valves for metal in the oil?
Would much rather deal with a small oil mess once in a while than metal in my engine oil lol. |
11-06-2017, 05:40 AM | #40 |
Thank you Al Oppenheiser!
it's an either vs. or thing, not both.
Magnetic Stahlbus or Fumoto valve? Not sure how that would work. If you attracted metal to the valve, it would likely foul it and prevent the valve from closing & sealing, causing leaks.
At which point you would have to remove the valve and clean it... which defeats the purpose. |
11-08-2017, 03:04 AM | #41 | |
11-08-2017, 05:30 PM | #42 |
Drives: Chevy Join Date: Jun 2017
Thread Tools | |
