Old 10-02-2016, 07:03 PM   #15
TMasticTB91
Tampa Bay Camaros
TMasticTB91's Avatar
Drives: '16 Hyper Blue 1LT
I was just thinking about doing this for my 1LT. Thank you for the write-up, definitely bookmarking this thread!
2016 Camaro 1LT | V6 | A8 | Hyper Blue
TMasticTB91 is offline   Reply With Quote
Old 10-03-2016, 03:51 AM   #16
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Great job. Very helpful.
Thanks
Old 10-03-2016, 06:59 AM   #17
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Hi Hyper1SS!,
this is a GREAT guide!! Thanks for sharing!
See you!,
Eos
Eos is offline   Reply With Quote
Old 10-04-2016, 03:01 PM   #18
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Your welcome and no problem. Glad to help
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 10-26-2016, 12:57 AM   #19
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Awesome write up, hold long did it take to install?
Richard0nee is offline   Reply With Quote
Old 10-26-2016, 04:13 AM   #20
Hyper1SS
Hyper1SS's Avatar
Maybe 45 minutes with removal of the old and running the wires.
Order ID: TDHQMS
Old 11-17-2016, 10:52 AM   #21
Pegasus1991
Drives: Blue Velvet metallic Camaro 1SS
I have been looking forever on where to buy these! Could you please tell me where to get them?
Pegasus1991 is offline   Reply With Quote
Old 11-19-2016, 01:10 AM   #22
Hyper1SS
Hyper1SS's Avatar
https://www.ebay.com/itm/282259242919
Order ID: TDHQMS
Old 12-21-2016, 08:22 PM   #23
Pegasus1991
Thanks for the install guide. Just got these for Christmas and couldn't be happier with them. Now the Camaro doesn't feel cheap when i open the door lol.
Old 01-20-2017, 10:38 PM   #24
bigwormgraphix
Drives: 1991 Z28, 2015 SS & 2017 SS
Nice write up and pics! Thanks!
bigwormgraphix is offline   Reply With Quote
Old 02-22-2017, 04:28 PM   #25
bub
Drives: '17 1SS 1LE & '15 Corvette Z06
Any idea of the GM part number for just the harness (assuming it even has a dedicated part #).
Bought a set of these sills but missing the harness on the cheap
bub is offline   Reply With Quote
Old 02-22-2017, 08:23 PM   #26
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
Try ThatGMPartsGuy he might know if you can get the harness or not. In theory you can just make it yourself. It just connects the two sides then splits so you can cut into the ecm wire.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 02-22-2017, 10:09 PM   #27
batmobile209
batmobile209's Avatar
Drives: 2016 Camaro SS
Looks awesome. Planning on doing this soon, thanks for the post my man!
batmobile209 is offline   Reply With Quote
Old 02-23-2017, 01:31 PM   #28
bub
I'm going to have to end up building my own custom harness and plan on using 2 factory style connectors to mate to the factory sill single pair "weather-pak" connector. The wire leads are quite small gage (almost like telephone wire) and I am a bit concerned that any connection other than the factory style connector, or just the "easy" cut and solder, could be problematic.
For anyone else ever in this situation, here are the parts that look to be needed to build the mating connector for a custom harness:
The conector on the sill pair of wires is a Molex (manufacturer brand) 33481-0201 (from the Molex 150MX series) connector with male blades, with + in terminal position 1 (note that sill illumination LED's will not work if polarity is incorrect).
I found this part number laser etched on the sill's connector, and searched for it online figuring out the above for part number. We also bench tested the sill LED's with alligator clips to determine/confirm polarity and that the sills actually work!
From online Molex drawings and specs that I was able to find online, we figured out that that mating connector is a Molex 33471-0201 (also 150MX series, but with "Key A" ear slots to mate to the sill connector ears), and are readily available online and on eBay. You really can find anything online.
http://www.motoparthub.com/NM_33471_...FQ-RaQode1oFPA
You will need the corresponding wire inserts and those are Molex 33012-2001 in tin coated female receptacle to 16 ga wire. They press into the back of the connector housing then you push the PTM into lock position to lock the 2 receptacles per connector in place...buy several to allow for mistakes in crimping, as they are cheap...also note that they are only made to fit into the back of the connector housing one way with the "guide" in the slot.
I know someone's reply will be "just cut the wires", but as an engineer I just like a challenge I suppose...once you have these connectors that mate to the sills the rest is just speaker wire, wire loom and some standard auto parts electrical splices and a ground lug.
