04-06-2017, 04:10 PM | #1 |
Drives: 2017 2SS Join Date: Feb 2017
Patching a Tire
So i get in my car this morning, and see that my passenger front tire is at 3PSI, I turn the wheel and get out of the car.... sure enough a screw in the tire.
I have 1100 miles on the car, and didn't get any type of road hazard warranty. What is everyone's opinion on just getting the tire patched? I called a few places and some wont do it at all, one place advised against it. and one place ( a goodyear center ) said bring it by, and we'll patch it. so what should I do? Take the free patch from goodyear, or buy a new tire for 345.00 ?
2017 Black 2SS Coupe
04-06-2017, 04:12 PM | #2 |
Retired from Car mfrs....
Patch it, if it's in the center tread. Virtually all tire manufactures allow one patch in the center.
Everyone, including dealers, either can't patch it, Or want you to buy a new tire. |
04-06-2017, 04:14 PM | #3 |
I've had plenty of patches in tires and have never had an issue, but I've also never had these F1 run flats before. The dealer said they wont patch them, because that would void the speed rating on them ?
04-06-2017, 04:18 PM | #4 |
I don't track my car so I don't care about the speed rating. If you track the car, it might be another story.
04-06-2017, 08:25 PM | #5 |
Drives: 2017 2SS 50th Anniversary Edition Join Date: Aug 2011
The stock tires can be patched. I had a nail in my front driver tire at 2k miles. I patched it at Discount Tire, made it a "spare", and put a new one on as peace of mind.
1100 - 04/29/16 | 2000 - 05/03/16 3000 - 05/04/16 | TPW 6/6 - 05/09/16 3100 - 05/25/16 | 3300 - 05/28/16 3400 - 05/31/16 | 3800 - 06/14/16, #125 Built! 4200 - 06/29/16 | 5000 - 06/29/16 6000 - 07/08/16 | Club F1FTY |
04-07-2017, 08:04 AM | #6 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
This just happened to me last weekend. I went to a local dealer on Monday and they wanted to put a new tire on the car for $315. The next day I went to a tire shop and they patched it for $18.
From what information I could find, patching it will be fine as long as the sidewall isn't damaged. If it fails again, then I'll buy a new tire. |
04-07-2017, 08:21 AM | #7 | |
Drives: 50th Anniversary 2SS M6 Convertible Join Date: May 2015
2017 2SS M6 H50 Convertible 1 of 158
1100 8/05/16 | 2000 8/08/16 3000 8/10/16 | TPW 9/5/16 8/13/16 3100 8/26/16 | 3300 8/30/16 3400 8/31/16 | 3800 9/8/16 PS#2293 4B00 9/10/16 | 4200 9/13/16 5000 & 6000 9/14/16 |
04-07-2017, 09:33 AM | #8 |
Agree. The problem with run-flats is you are on borrowed time driving on the sidewalls once the pressure drops. Once the sidewalls crumble you have trash and it's not worth patching. They say 50 miles. Probably worth carrying a small compressor so you can keep the pressure up if you are lucky enough to get a slow leak. Then you are good for hundreds of miles.
04-07-2017, 11:43 AM | #9 |
Sparky
Drives: 2017 50th Coupe / 2017 ZL1 Join Date: Mar 2017
Ok, this is my first time with run-flats so not sure . . .
I always keep a compressor and a tire plug kit in my vehicles, used quite a bit and works great. (NOT the rubber plugs, but the rawhide/glue impregnated type). Puncture hole must be on the flat contact part of the tread only. And if this was a tire that saw the track - maybe a patch. Mark |
04-07-2017, 05:03 PM | #10 | |
04-07-2017, 06:40 PM | #11 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
Got a compressor and a plug kit in the trunk. Luckily, haven't had to use it yet.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
04-07-2017, 08:40 PM | #12 |
Drives: 2016 SS Nightfall Gray Join Date: Oct 2016
I had run flats on Vettes before, and I always carried a plug kit and compressor.
I probably plugged 4-5 tires ( tread area only ) and drove 1000s of miles with no issue. I was not tracking, but commuting across the desert at, let's say, 3 digit speeds with no problem. |
04-07-2017, 10:00 PM | #13 |
Plug it. It's completely safe. Ya gotta luv the "You can't repair run flats" BS that some places try to pull.
04-07-2017, 10:13 PM | #14 |
Drives: '17 2SS A8 Nav NPP Join Date: Jul 2016
I agree with everyone else. I've patched/plugged many tires and never had an issue.
2017 Summit White 2SS | A8 | Nav | MRR M017's | Nitto NT555 G2's 285/30, 305/30 | GM Strut Tower Brace | Gloss Black GM Front Splitter | GM Dark Tail Lights | Black front Bowtie rear Bowtie delete | Oracle LED Side Markers | Roto Fab CAI | SEMA grill | Borla S-Type axle back | Borla X Pipe/Mid Pipe w/2nd cat deletes | Power Stop Z26 pads | BMR sway bars & end links, upper/lower trailing arms, upper control arms, chassis braces | ACS ZL1 style rockers | OEM ZL1 rear spoiler | ZL1 start button | Mishimoto catch can | ZL1 6 Pots w/2 piece 390mm rotors | Valentine 1 hard wired | Husky Liners |
