04-24-2017, 01:06 PM | #15 |
Drives: 2017 Camaro SS Join Date: Jul 2016
I'm going to get flammed for this but I'm from rural Iowa, sometimes you CAN'T get premium so you make due.
The LT1 will run just fine on 87 ethanol. FYI the dyno numbers in my signature were made on 91 octane no ethanol.
2017 2SS Black NPP A8 - 422 HP 427 TQ
04-24-2017, 02:36 PM | #16 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
The best I can buy is 91, NEVER had a problem. If You buy the best that you can find You'll be all set!!!! It will run just FINE!!!!
04-24-2017, 03:31 PM | #17 |
Drives: 2016 Red Hot 2SS Join Date: May 2016
Ok so out of curiosity I looked in the manual that came with my 2016 2SS - it says the same thing as myChevrolet app does, 91 for v8.
Not sure why GM changed it in 2017 manual. |
04-24-2017, 05:33 PM | #18 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Flamed yes, main because while the LT1 can "run" on 87 it states in the manual only to do it in emergencies and to fill back up with 91 or higher otherwise engine damage can occur. GM has gone as far as to say if you are caught running 87 octane and have engine damage they will not warranty the repairs if that is the case. |
04-24-2017, 05:41 PM | #19 |
Sparky
Drives: 2017 50th Coupe / 2017 ZL1 Join Date: Mar 2017
If you don't develop any knock or knock detection, then you are correct - no additional performance from a higher octane. However, if knock is detected the controller will drop to the "low octane" table. Resetting to the normal table used to require a full fuel fill-up - not sure if that is still the case.
Mark |
04-24-2017, 05:48 PM | #20 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Knock doesn't guarantee the use of the low octane table. If knock is detected it will pull timing immediately. If the knock retard exceeds a certain threshold it will start to increment the knock learn factor. Think of this factor as a slider between the low and high table. The higher the factor the more it biases towards the low octane table. If knock is not detected any longer the knock learn factor will start to decrement and will head back towards the high octane table. I've seen tunes where people raise the low octane table. Unless it is a track only car running known fuel this is bad practice.
Tim |
04-24-2017, 06:12 PM | #21 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
04-25-2017, 10:16 AM | #22 | |
As to the LT1 getting better fuel economy on 93 vs 91... good luck measuring that. Theoretically that may be accurate, but the difference is going to be so small that it's probably not statistically significant. |
04-26-2017, 12:38 PM | #23 | |
Drives: 2016 2SS Join Date: Oct 2016
Not sure anything else than a dyno can detect if the car is running 91 or 93 as far as performance goes. As far as causing damage to the engine, it won't. If you really care and want to feel the difference between 91 and 93, you can buy some Torco Accelerator and add to your tank to reach 93 octane or even higher level of octane. It works, many people are doing this as an inssurance when going to the track, especially tuned car. Just be aware if you use it on a regular basis, your exhaust will get a red tint because of the Torco. Same with your spark plugs and the inside of your motor. Last edited by alexandre_baril; 04-28-2017 at 11:42 AM. |
04-27-2017, 09:09 PM | #24 | |
Drives: 2017 Camaro 2SS Mosaic Black Join Date: Apr 2017
Thanks everyone for all the great info. I've been filling up with 92 and no issues what so ever. |
