09-04-2017, 09:28 AM | #1 |
IG @Brian_ _Self
Drives: 2010 Camaro 2SS M6+17'Tesla Model S Join Date: Nov 2012
Chewed my differential.
Hey guys. Long time no talk haha. Long story short I got a Tesla and have been occupied with the different form of mechanics it brings with it and being able to just punch it whenever and not worry so much and I forgot 100% that my Camaro has the stock rear gear in it and couldn't hold my full power... did a clutch dump and riiiiinerrr went my rear end.
I haven't had the chance to pull it apart yet, but after we pushed it to the side, I did a test of the movement again, and it moves a little bit, but went back to making the grinding slip noise after about 10in of movement forward movement under its own power. I've never done one before so I'm trying to get a few ideas. 1. % Chance of it being the spider gears (if I'm correct a possibility) 2. Probably going with 3.91s on my existing Cam setup with 48x-whp / 47x-tq Sound like a good idea?- Coming from my SS 3.45s to the 3.91s for a good street setup (no top speed runs is what I mean) ...I know it's discussed a lot.. Also I will say my 3.45 gear and current setup would pull about a car length on a factory CTS-V from a 40 roll. I'd like to keep that statistic or better it... we use each other as a benchmark. 3. Best brand for durability for future mods and quietness of the gears. I've heard good about AAM and heard a little bit about Motive products and Yukon around town.. Whats everyone's thoughts?
09-04-2017, 10:43 AM | #2 |
Drives: 2010 Camaro SS Join Date: Oct 2013
Are you sure it is not just a broken axle?
If it is the diff and you want stout get a ZL1 lump.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
09-04-2017, 12:20 PM | #3 |
IG @Brian_ _Self
Unless it shredded the splines, I wouldn't think axle. I looked under and they still look like they're in good shape..
09-04-2017, 01:58 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
4.10
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
09-05-2017, 07:41 AM | #5 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
GM 3.91 gears works well in a 6 speed manual car.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
09-05-2017, 09:35 AM | #6 |
Instagram: Sangstah
+1 for the 3.91 for sure!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-05-2017, 09:45 AM | #7 |
GPI Sales Consultant
+1 for the 4.10. You've got the cam to let her scream, now time for the gear to keep her wound up.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
09-05-2017, 10:49 AM | #8 |
Right. 3.91 for stock cam.
09-05-2017, 11:01 AM | #9 |
Well - I love the 4.10 with the stock cam. It suits a stock or modified cam with an M6, IMO. I have a feeling that a 4.10 with the 4.027 in the 6L80 would be a bit extreme. Plus the 1.152 4th gear would probably not make the quarter mile on a modified car.
09-05-2017, 03:36 PM | #10 |
IG @Brian_ _Self
Just to be clear guys, I meant my Cam setup is aftermarket... not stock, stage 3 TSP... I would jump on the 4.10 but I think it may just be a little high for me now with the cam setup... maybe even 3.91 is too high...but I like the feedback people have been giving about it...
Also my shop said there's a possibility it could be the output shaft of the trans... soo I'll be waiting on that update when they get a chance.. If in that case of it being the output shaft, I'll do clutch while in there, output shaft, carbon syncros, bronze shiftpads and a bronze cup.
09-05-2017, 04:26 PM | #11 | ||
Drives: Miss Con Ception Join Date: Aug 2016
2011 1SS/RS LS3 CGM
09-05-2017, 05:33 PM | #12 |
My posts in this thread for manual cars like the OP.
09-08-2017, 08:17 AM | #13 |
IG @Brian_ _Self
They looked more in depth today and it’s the ring and pinion like I originally thought.
So far looking like it will be the 3.91s. Anyone have any brand recommendations? Also what’s needed for this... I see some people mentioning just the gears but some saying a whole install kit from GM. Which was like 400$+ on a few sites. They’re in the middle of a move so I’ve got some time to bring them the parts.
Tags |
broke, differential, rear gears |
