Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 03-24-2017, 03:52 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2016 1SS
Thumbs up Hendrix Engineering Differential Bushings @ Phastek Performance
NOW AVAILABLE!!
FREE SHIPPING @ Phastek Performance!!
IN-STOCK AND READY TO SHIP!!
The Hendrix bushings are a great way to help eliminate wheel hop and decrease 60ft times in the quarter mile. Their offset design accounts for the articulation of the factory suspension under heavy load and will benefit the half shafts by taking some of the deflection caused by a heavy load.
Phastek Performance offers 3 different versions of this kit. The Polyurethane will be the softest version available and Delrin will be the hardest version available. BUT what we have done is come up with a kit that will get you the best of both worlds, the Combo will give you 1 Delrin and 2 Polyurethane.
Features:
Helps eliminate wheel hop
Increases holding power of axles
Decreases 60ft time
Increases longevity of CV joints
Fits:
Camaro SS, 1LE, and ZL1
Polyurethane:
Delrin:
Combo (1 Delrin and 2 Polyurethane):
Sales@Phastek is offline   Reply With Quote
Old 05-12-2017, 01:45 PM   #2
Sales@Phastek
Drives: 2016 1SS
Old 11-29-2018, 06:48 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Do you have any of these in stock??? Looks like everyone is out... what's up with that?
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-09-2018, 02:17 PM   #4
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Yes, looking for a poly set myslf.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
flht99b is offline   Reply With Quote
bushings, diff bushings, differential, hendrix, phastek
