Old 09-26-2017, 03:15 AM   #43
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
LSA heads are done... Smoothed all of the razor edges that these heads have
Wing and rough chamber:
No wing and polished smoothed chamber:
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 09-26-2017, 07:01 AM   #44
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Nice Job!!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 01-25-2018, 02:51 PM   #45
racesloth
Dan
New 3" MRBP cat-back arrived today also going with a Pat G cam now...
Dan
2010 IOM SS
Old 01-26-2018, 08:50 AM   #46
BiggFoot
BiggFoot's Avatar
When is dyno day?
Blower Cam
RPM Level VII
TR6060
Old 01-26-2018, 03:54 PM   #47
racesloth
Dan
Not for a while - I am so busy with work and the CEO is flying in for a visit next week too...
Dan
2010 IOM SS
Old 02-14-2018, 05:28 AM   #48
racesloth
Dan
Sold the BTR PD cam and the new PatG-TSP cam arrived 224/240 .615/.615 112 - can't wait for warm weather...
Dan
2010 IOM SS
Old 04-22-2018, 05:54 AM   #49
racesloth
Dan
Made a cut out last night for installing the ZL1 fuel pump I used a dremel with the thin cut off wheel and made sure not to penetrate deeper than the sheet metal thickness - only took 20 min. Was careful and didn't touch anything underneath. Install was straight forward and then installed the FPCM.
Next up is the cam install.
Dan
2010 IOM SS
Old 05-27-2018, 09:24 AM   #50
racesloth
Dan
Swapping out the Vengeance cam. Two broken lifters - the area around the outer pushrod cup collapsed the disk underneath was chewed and the retainer clip all distorted. Pushrod was holding it together. Engine ran fine right before tear down including some full throtle pulls. Got lucky I guess - looks like more than normal wear on the Vengeance VPRSP II Comp cam installed JUL 2013.
Dan
2010 IOM SS
Old 05-27-2018, 09:25 AM   #51
racesloth
Dan
Put the new cam in yesterday and decided to inspect the oil pump. Damage to the gerotor gears. Looked like it ingested some metal maybe from the broken lifters. - time to order a new 10296 pump. :(
Dan
2010 IOM SS
Old 05-27-2018, 09:39 AM   #52
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
bummer! quick question...did you inspected/take any pic's of the lifter bores with the damaged lifters? based on what you wrote I don't believe they should have any damage but since the oil pump was damaged I would be checking that...and did ya get a bright light on the cam bearings too? if they had any scratches wonder about the main/rod's?
just helpin/hopin you get it all sorted out the first time.....good luck!
peace.
btw - post sum pics of the oil pump damage..plz..and cam too..
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 05-28-2018, 11:13 AM   #53
racesloth
Dan
I did check the lifter bores they are perfect - same with the cam bearings. The roller lifters are slightly worn and the camshaft is showing signs it is starting to go. The pic of the two lifters by themselves are the two that had the pushrod cup break.
Dan
2010 IOM SS
Old 05-28-2018, 11:19 AM   #54
racesloth
Dan
Pistons before and after
Pistons before and after. Cleaned up really easy with some carb cleaner and scotch brite. This LS3 has 35400 miles on the clock.
Dan
2010 IOM SS
Old 05-28-2018, 12:06 PM   #55
frankwjr
frankwjr's Avatar
I see what you did here!!!! lulz....tks fer da pics...that cam definitely was about to go...the surface hardening was all but gone....wonder what it was about those 2 lifters? and which 2 were they? not adjacent were they?
the cam failing would explain the lifter rollers lookin like sh!t...I wonder if it was debris in the oil the got into the lifters pluggin them up and causin failure...
peace
Old 05-28-2018, 12:40 PM   #56
racesloth
Dan
I am not really sure - it was very odd but the two that broke cam off of different cylinders on opposite banks. As far as heat treating went, I count myself lucky since 2013 was in zone where they had heat treating issues and I figured since mine had gone so far without failure my cam must have had a proper heat treating...not that proper it seems.
Dan
2010 IOM SS
cam, id850, twin disc, whipple
