12-08-2017, 07:21 PM | #15 |
Drives: Love the one you're with Join Date: Sep 2009
12-09-2017, 09:18 AM | #16 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
12-09-2017, 09:24 AM | #17 |
Seafoam is pretty mucha joke. It makes your car smoke so you are made to believe that something is happening. I have a family member that works at a dealership as a mechanic. He said it never fails wit GDI motors. They have him do some type of chemical cleaning that never works only to have the customer come back to have the top of the motor torn down for a manual cleaning. GDI motors suck. I dont care what anyone says.
12-10-2017, 02:10 PM | #18 | |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Now how dangerous it is to sensors? It's more so the crap that it pulls out the motor thats dangerous to them, so if your motor has alot of carbon build up on it, you risk fowling out some sensors..I've yet to do this fortunately..but it is possible. |
12-11-2017, 03:56 PM | #19 |
Drives: 2017 2SS Join Date: Oct 2017
Is there any evidence of a carbon build up issue on the intake valves of the LT1?
All I can find is people talking about the possibility of this referencing other makes of cars. If it isn't broken- don't fix it. Just enjoy the car, there's nothing wrong with it. Put some stripes on the fenders or something. You'll feel better.
Last of the V8 Interceptors!
12-11-2017, 07:22 PM | #20 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
You can use Seafoam but, GM has a top end cleaner that is top notch. What is it..... Techron.
The trick to making sure it works is employing properly. You don't want to use the brake hose, too big. Source a 5/16 sized nipple. You can use PCV nipple and size it down or restrict it. It's going to take 2 people, 1 at the can, 1 to operate the throttle. Introduce a small about to coat the intake tract. Then as you get down to about half the can start flooding it until it stalls. If done right it should have sucked down about half. Let it set and soak for about 30 mins. and then fire it up and blow it out. If there's any in the can just put it in the gas tank. |
12-11-2017, 07:49 PM | #21 | |
I used to be Dragoneye...
12-11-2017, 08:05 PM | #22 |
Was told by my parts guy that the GM Top End Cleaner was rebranded Trechron when he didn't have any. Hes been my go to guy for 30 some years. BG 44K also works good.
12-11-2017, 08:32 PM | #23 |
12-11-2017, 08:55 PM | #24 | |
X66p is the top half cleaner that GM uses and its very different than Techron. you dont put x66p in your tank and you dont put Techron in your intake. Two different chemicals for two different functions. |
12-11-2017, 09:01 PM | #25 |
Many studies are proofing that catch cans arent doing much to solve this issue, and there are only a few brands out of the many that do anything at all. People keep saying about fuel not hitting the back of the valves in GDI motors. That's correct, but the coking and carbon build up comes from more than the PCV system. Valve overlap allowing some combustion gases to hit the back of the valves for one and valve seal leaks to name just two. A catch can will do nothing for either.
12-11-2017, 10:41 PM | #26 | |
GDI engines are notorious for oil coking on the back side of the valves due to blow by from the PCV system. The intake manifold, intake ports on the heads, along with valves get coated with oil. Since direct injection sprays fuel directly into the combustion chamber, fuel does not make contact with the intake ports or valves. I use a chemical spray from CRC through the throttle body with the engine running. You have to disconnect the maf so the ECM reverts to speed density and will run without the intake hose connected. A CEL will popup but can be easily cleared. Seems to have made a difference on my 2012 GMC Terrain GDI 2.4. 80k miles and going strong. First time I cleaned it around 50k miles it smoked like crazy out the exhaust. The last couple times not so much.
2016 NFG 1SS A8
12-13-2017, 12:11 PM | #27 |
Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
Completely irrelevant when talking about DI engines and how they operate. Obviously changing oil regularly and using 93 octane should be done anyway but it won't magically make the carbon build up stop.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. |
12-13-2017, 01:52 PM | #28 |
True - it won't...yet, I don't think it's fair to say its irrelevant, either. There are processes that can be done (albeit invasive) 80 - 100,000 miles down the road to return the valves & seats to new. So for many people, just leaving it alone is what you do.
