Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Interior Parts & Accessories
Old 05-10-2023, 02:03 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2023 CAMARO ROTO-FAB COOLANT EXPANSION TANK COVER
Available here - https://www.southerncarparts.com/201...ank-cover.html
The Roto-Fab coolant expansion tank cover was designed to cover the factory OEM coolant tank to clean up the Camaro's engine bay. The cover is constructed out of injected molded plastic that has a factory look and feel.
Installation is done by simple removing the factory over flow tube at the top of the factory tank. This will allow you to place the hose into the provision made on the Roto-Fab cover. Once the hose is feed through the hole you can reinstall the factory clamp and slide the cover in place. The optional billet coolant cap is available separately. Please install when your Camaro is at ambient temperature, do NOT attempt to work on it while the coolant is hot.
FEATURES:
  • Textured Black Finish
  • Injection Molded Plastic
  • Sight Window to View Coolant Level
  • Easy Installation
APPLICATION: 2016, 2017, 2018, 2019, 2020, 2021, 2022, 2023 CHEVROLET CAMARO
SCP Coupon Codes:
SCP5 - 5$ OFF For Orders > $125
SCP25 - 25$ OFF For Orders > $275
SCP50 - 50$ OFF For Orders > $550
southerncarparts is offline   Reply With Quote
