View Poll Results: Which cam for BEST overall performance- drivability/hp/trq | |||
P-233/248 .627"/.612" | LSA 113+5 | 7 | 18.92% | |
B- 233/250 .619"/.595" | LSA 113+5 | 14 | 37.84% | |
T- 235/239 .627"/.624" | LSA 112 | 16 | 43.24% | |
Voters: 37. You may not vote on this poll |
Thread Tools |
02-28-2016, 01:30 AM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
3 cam selections.-
Finally norrowed it down to 3 cams for the setup. Input would be appreciated. Researched high and low with vids/forums etc. Just wanted to see everyones input.
14'' 1LE P-233/248 .627"/.612" | LSA 113+5. B- 233/250 .619"/.595" | LSA 113+5 T- 235/239 .627"/.624" | LSA 112 Last edited by RupertPupkin; 02-28-2016 at 09:10 AM. |
02-28-2016, 02:24 AM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Cylinder head details.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
02-28-2016, 07:34 AM | #3 |
02-28-2016, 08:35 AM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
Its the 1st time I see someone with cam selection that big LOL Id go with the 235 239 without hesitation. Been dyno tested with nice results. Other cams seem very large and might be slugish with a heavy 3850lbs car unless having 4:10 gear. TSP are very confident with their 235 239 but I did choose 231 236 over it cause they were very close in performance with the 231 having better low and early-mid torque/hp.
It only makes 10hp more up top. I chose 10hp/tq down low... I would not go with other cam unless they were spec'ed for you with your setup. I hope you do not run heavy wheels and stock SS gearing... BTW friend of mine is running a 230 240 595' 595' in his LS3 Vette and I find it kinda lazy down low and it wakes up at 4k...not good IMO.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 02-28-2016 at 08:47 AM. |
02-28-2016, 09:10 AM | #5 |
Drives: 2014 SS Join Date: Apr 2015
I voted 235/239, but that's because I have one lol
Toys:
2014 SS - TSP 235/239, CAI, LT's, 12.2 @ 115 ("SLOWLY" chipping away ET) 2000 Trans Am - Bolt-ons 13.0@110 (sold) 2009 YZF R1 - Race bike (road course)(totaled racing) 2008 YZF R6 - Race bike (road course)(still own) |
02-28-2016, 09:21 AM | #6 | |
All the cams are pretty damn good imo, and looks tolerable as far as using it for DD. I see your point on the 231/236. Good feed back on that cam, and saw the dyno chart. Go big or go home right.. Hows the drivability? DD? |
02-28-2016, 09:25 AM | #7 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
Having done a milder than those cams from a 235/239 with 112 LSA which was .639/.623 to now a .613/ .578 with 114+4 223/ 234
I can honestly say the LSA matters kind of maybe in breaking vacuum ..... other than that drives the same kind of no big break on drivability, some day I may go ls7 heads and want to know with 1.8 rockers instead I will not be in the stratosphere..... ( adds about .50 lift so a 613 becomes 663... a .578 becomes 628.....) . The TSP is a strong pulling cam though that's not exactly the CAM you listed as 235/239 they may just use the same duration and LSA, and I know they went back and modified it from when I got it to loose .010 on the intake lift last I heard. I made 491 hp and 448 torque with just a CAI, headers and tune on my 13 with the tsp cam stock ls3 on a mustang dyno.
02-28-2016, 11:55 AM | #8 |
Not a DD. Drivability and a cam that size shouldn't be used in the same conversation lol.
Toys:
02-28-2016, 03:08 PM | #9 |
02-28-2016, 05:44 PM | #10 | |
235 239 is tight with stock heads BTW with an LS3. Other cams going to melt valves/pistons together.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-28-2016, 07:05 PM | #11 |
02-28-2016, 07:12 PM | #12 |
13' 1LE
02-28-2016, 08:50 PM | #13 |
Toys:
02-28-2016, 09:12 PM | #14 |
