Old 05-09-2020, 09:56 PM   #15
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by ZL1 1LE View Post
Is a 6’ extension cable the answer?
Yes, that will provide enough length to go through the grill. Much easier than opening and closing the hood. Just don't forget it is there before driving away
1hprush is offline   Reply With Quote
Old 05-10-2020, 02:26 PM   #16
KirkH
Originally Posted by zag View Post
Instead of running the wire across the top to the hood latch hole, run it straight down between the battery and radiator and fish it through the lower grille and zip tie it to one of the grills opening, This is how I ran mine,just a suggestion.
There is also an opening behind the upper grille next to the headlight housing that will allow the wire to pass thru. I used a fish tape, took 30 secs.
Old 05-11-2020, 07:13 AM   #17
craigss50
craigss50's Avatar
Drives: 2017 Camaro SS Fifty
Thank You. Just hardwired mine up as well. Pics and info were spot on and appreciated.
craigss50 is offline   Reply With Quote
Old 05-11-2020, 03:08 PM   #18
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
I'll go Glen e's black duct tape one better. I'm going to use these peel off adhesive plastic tie holders:
Old 05-11-2020, 10:32 PM   #19
Haoie
Drives: 2017 50th Anniversary SS
I'm curious, should I get a battery tender if I daily my car?
Haoie is offline   Reply With Quote
Old 05-11-2020, 11:02 PM   #20
KirkH
Not unless you are having hard starts due to a possible parasitic drain. Probably just be a waste of money.
I haven't driven my car in months.
Old 05-12-2020, 04:30 PM   #21
Ron2ss
Ron2ss's Avatar
Drives: 2020 2ss vert
Originally Posted by 1hprush View Post
Thanks to forum member Glen e for the install suggestion. Here are some pics that I took today during my install.
Remove the cover that's next to the fuse box. Push down on the tabs and lift. Attach your (+) feed to one of the empty post, I used the 4th post, and attached the (-) feed to the negative bolt, and then snap the cover back in place. I ran the cord through the hood latch and out through the front grill. Enjoy!
I have been using the clips also but decided to hardwire mine today. The two unused posts #'s 4 and 5 are not hot in my car therefore will not pass current from the battery maintainer. Does anyone know where to place a fuse in the fuse block to make either of those two posts live?
Ron2ss is offline   Reply With Quote
Old 05-12-2020, 06:54 PM   #22
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
I was wondering about that. My 6' extension cable won't be here until Monday for me to finish my install.
Old 05-13-2020, 05:29 PM   #23
GroundhogSS
GroundhogSS's Avatar
They should all be hot. I think they are all on the same buss bar. I have several things on number 4 that always have power.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers
Delivered: 08/15/2016
#TeamBeckyD
Old 05-13-2020, 11:57 PM   #24
Ron2ss
Ron2ss's Avatar
Nope, they are not as verified by my Fluke Multimeter.
Old 05-14-2020, 01:44 PM   #25
GroundhogSS
That strange. Mine is also a 2SS, just three years older.
Richard
#TeamBeckyD
Old 05-14-2020, 01:47 PM   #26
threetime
*PIMP*
Drives: 2018 2SS
Battery Tenders are never a waste of money.
threetime is offline   Reply With Quote
Old 05-15-2020, 12:48 AM   #27
Ron2ss
Ron2ss's Avatar
Is there any way you could determine what fuse location supplies power to post #4?
Thanks
Old 05-15-2020, 01:14 AM   #28
RenegadeXR
RenegadeXR's Avatar
Drives: 2011 Camaro SS
If your battery was draining that quickly overnight, you'd have much bigger problems, and a battery tender wouldn't be the solution. It's really for when a car is sitting stationary for weeks or months.
That being said, I'd still recommend getting one. You never know when your driving habits could change. Maybe you get a 2nd car. Maybe you decide to ride a bike to work. Maybe a global pandemic hits.
They are super easy to use. You can just put the one alligator clip on the positive battery terminal (the red cap seen in some photos posted here) and one on the ground pin at the side of your engine bay. The folks in this thread are using a slightly more complex method of wiring extension leads into their engine bays. To each their own, but I don't mind popping the hood each time.
Disclaimer: Unless specific sources are cited, all of the above is my subjective opinion. No warranties, expressed or implied, are granted. This is a car forum, after all.
RenegadeXR is offline   Reply With Quote
