Old 04-10-2023, 07:24 PM   #1
jstanton
jstanton's Avatar
Drives: 2022 Camaro 2SS 1LE
Seat Belt Guide Modification
My wife complains about the seat belt being too far back for her, she is only 5' tall, when her seat is adjusted forward. I've never really noticed it but she has complained enough so I went looking for a solution. I didn't find anything specific for the camaro or the recaro seats for that matter but after doing some measuring on the headrest posts I found these that are made for the mustang.
https://www.ebay.com/itm/36407313856...3ABFBM4un22e1h
The hole spacing and diameter fit perfectly for the Recaro headrest. The only issue is the loop doesn't clear the shoulder of the seat so the body of the guide under the headrest rides at an angle on the posts. I think I'm going to take them back off and use a heat gun to either slightly angle the loop forward or up so that the body of the guide will lay flush on the seat under the headrest.
Overall I think it works well and fits with the style of the Recaro seats, even if it is for a Mustang!
On a side note the release mechanism for the Recaro headrest is different from what I've read on here. I found it best to slide the rear seat all the way forward and sit in the back with the seat leaned back toward you. With the headrest fully extended, twist the plastic cover around the base of the post counterclockwise to remove. There is a release pin in the 11 o'clock position, when viewed from the back seat. It is at the base of the black plastic piece that is around the headrest post inside the seat. Use a small flat heat screwdriver to push the foam and leather out of the way, and you should be able to see the metallic pin. Use the flat head screwdriver to lift up on the pin while pulling up on the headrest. This will release that post. Repeat for the second post while keeping tension on the headrest so the first post dosen't lock back into position. The pin can be stubborn so it may take a few attempts. Also using a headlamp really helped since your trying to hold the headrest and release the pin simultaneously.
Hope this helps someone in the future!
jstanton is offline   Reply With Quote
Old 04-10-2023, 07:28 PM   #2
jstanton
jstanton's Avatar
Not sure why that photo loaded upside down.
Old 04-10-2023, 07:28 PM   #3
jstanton
jstanton's Avatar
Dang it! Did it again! Oh well, you get!
Old 04-10-2023, 08:56 PM   #4
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
What if you turn it upside down (not the pics)?
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 04-10-2023, 09:05 PM   #5
jstanton
jstanton's Avatar
It's hard to tell in the pictures but the body of the guide has a slight curve to it also. So when you turn it upside down, it curves to the back and blocks the seat release lever.
Old 04-11-2023, 08:41 AM   #6
ember1205
Hot Camaro
ember1205's Avatar
Before the Camaro, I always grabbed the seat belt the same way - when driving, I reached back with my right hand over my left shoulder. With the convertible Camaro, that's not an option even with the seat all the way back. I simply changed to where I reach back with my left hand along the seat/floor. This works in all of my cars, so it was easy to make the change stick even though I don't drive the Camaro anywhere near as often as the other vehicles.
Old 04-25-2023, 10:23 AM   #7
sspddmn
sspddmn's Avatar
Drives: 2018 ZL1 1LE and 1991 Z28
I did the same mod using a different seat belt guide for a BMW. You can click below to see what i did. Only thing i would change is to add some kind of hinge underneath at the same time you put in the epoxy because the hinge does come off from time to time and it gets annoying.
https://www.camaro6.com/forums/showthread.php?t=582916
In the garage: 2018 HBM ZL1 1LE // 2013 ZL1 (sold) // 1991 Camaro Z28 5.7L // 2016 Audi A6 Prestige Supercharged 3.0 V6 // 2002 Camaro SS (sold)
sspddmn is offline   Reply With Quote
Old 04-25-2023, 02:43 PM   #8
MANNAXMAN
MANNAXMAN's Avatar
Pretty sure I've been doing it this way since I had my 1986 IROC. Prior to that, my daily driver was a 1964 VW Bug with lap belts only, so I was already in the habit of reaching down to the floor with my left hand to grab the seat belt.
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 04-25-2023, 02:45 PM   #9
ember1205
Hot Camaro
ember1205's Avatar
That would make sense since your habitual method would work right off the bat... No need to adapt anything. I definitely had to make a big change because there is really no way of grabbing the shoulder belt in the convertible by reaching across your body unless you're a bit of a contortionist.
headrest, recaro, seat belt, seat belt guide
