Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
JDP Motorsports
Old 08-21-2017, 11:10 AM   #1
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
ZL1 1LE ride height adjustment
Anyone with a ZL1 1LE adjust the height on their cars yet?
Just curious how easy/hard it is. Pictures would be cool as well.
Thx
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 08-21-2017, 09:42 PM   #2
Dwille
Drives: 2018 ZL1 1LE
This weekend I'll be playing with the ride height and camber plates. I'll let you know how it goes!
Dwille is online now   Reply With Quote
Old 08-21-2017, 11:23 PM   #3
trakdayz
Drives: bmw e92 m3
stupid you can only lower or raise the front, makes no sense to me
trakdayz is offline   Reply With Quote
Old 08-21-2017, 11:26 PM   #4
nighttowl
nighttowl's Avatar
Thx
So how long until you buy one?
You know you want to.
We know you want to.
2018 MBM ZL1 1LE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 08-22-2017, 09:57 AM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
I know I Know......
Gotta take the wife to Hawaii first. lol
Mods:
Old 08-22-2017, 03:01 PM   #6
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
The height adjustment for the front only isn't for the Stancenation look, it's for handling.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 08-22-2017, 03:17 PM   #7
Andi
Drives: ZL1 1LE
The adjustment is quite easy and instantly familiar if you've ever adjusted a coilover spring perch. Just loosen the allen bolt (don't remove), rotate the perch to adjust up or down as illustrated in the owners manual high performance supplement to the desired position, and re-tighten the allen bolt. A lower front ride height will translate into less understeer / more oversteer and has the side effect of looking better as well (at least in my eyes).
Note: the car doesn't come with a spring perch adjustment tool. You can buy one or, in a pinch, you can use a pair of allen wrenches to get the right leverage to rotate the perches.
Hope this helps.
Cheers,
Andi
'18 Camaro ZL1 1LE
'15 Charger Hellcat
Andi is offline   Reply With Quote
Old 08-22-2017, 04:35 PM   #8
wstaab
Drives: 69 Z28, 2018 ZL1 1LE
Front shock spring seats are adjustable to corner weight the car for track use.
Rear suspension ride height is not adjustable to maintain suspension geometry and toe curve.
https://grassrootsmotorsports.com/ar...orner-weights/
wstaab is offline   Reply With Quote
Old 08-22-2017, 10:30 PM   #9
trakdayz
Drives: bmw e92 m3
awee thats cute, you think im part of that stupid "stance" thing. Clearly you know nothing about proper suspension tuning and geometry. Proper height adjustable coilovers are to be upfront and rear, not only front. I track and tune my cars and clients cars "at the track"..... just doesnt make sense why the front can only be "height" adjustable.
Old 08-23-2017, 11:09 AM   #10
Tim202
And (this is probably obvious, but going to ask anyways) can the camber adjustment be done without removing the wheels?
Tim202 is offline   Reply With Quote
Old 08-23-2017, 11:31 AM   #11
Andi
Drives: ZL1 1LE
The first time, yeah, it's a pain in the butt to get to and undo the Allen bolt on the underside of the strut upper mount. After that, no. That said, it's still not that quick or easy to rotate be struts so my recommendation is pick a permanent alignment spec that fits your needs and leave it there.
Cheers,
Andi
'18 Camaro ZL1 1LE
'15 Charger Hellcat
Old 08-28-2017, 10:44 PM   #12
Andi
Drives: ZL1 1LE
You can see in this pic the allen bolt that needs to be loosened to rotate the assembly and adjust ride height. The other allen bolt, for getting the aggressive camber setting, is much harder to get to.
Cheers,
Andi
'18 Camaro ZL1 1LE
'15 Charger Hellcat
Old 08-29-2017, 11:06 AM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Thx for the pic.
So I hear you can get as much as -3.7 camber with the most aggressive adjustments...
Mods:
Old 08-29-2017, 07:49 PM   #14
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28, Challenger
You can use the same allen wrench to turn the bottom spring adjuster by inserting into the holes. I lowered mine by 5mm It tells you in the book that comes with the car how many turns make the change height in mm
Skylane765 is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
