02-20-2015, 11:14 AM | #1 |
Drives: 1995 m6 F1a Join Date: Jul 2014
is this a 1le?
02-20-2015, 11:29 AM | #2 |
Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I think you have to get a build sheet for that VN to figure that out. It is a 2SS with a manual, so its possible.
02-20-2015, 11:40 AM | #3 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
How about a pic of the rest of the car from different angles?
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
02-20-2015, 11:57 AM | #4 |
02-20-2015, 12:03 PM | #5 |
HTCC Member
Drives: 2018 ZL1 1LE HBM Join Date: Oct 2014
It looks like a 1LE
02-20-2015, 12:03 PM | #6 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Here's a sure fire way to know...
Open the hood...take a look at the steering column. If it's white....it's a 1LE.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
02-20-2015, 12:06 PM | #7 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Check the "Service Parts Identification" sticker in the trunk. Pull the trunk carpet back on the left side, next to the spare tire well. Silver sticker with 3 digit codes. If there is a 1LE code, then yes.
02-20-2015, 12:07 PM | #8 |
Dazed &
Drives: matte blue 2014 z28(186) 2015 R1 Join Date: Jun 2013
i think its missing a door LOL
02-20-2015, 12:10 PM | #9 |
Looks like this:
02-20-2015, 12:13 PM | #10 |
Drives: 15' Scat Pack Join Date: May 2014
Bottom right of that sticker says 1LE, so yes
02-20-2015, 12:16 PM | #11 |
It's a 1LE. Bottom full row, 3rd in from right "1LE". I don;t know all the codes, but it looks like they opted out of the door option. My guess this is a stripped down version.....get it?
02-20-2015, 12:23 PM | #12 |
02-20-2015, 12:25 PM | #13 |
Drives: car Join Date: May 2008
Searched the VIN. Found a post on Camaro5 where Becky Rodgers posts that it was a 1LE "built and bayed" for a member here named dynabyte.
Thread when he got it: http://www.camaro5.com/forums/showthread.php?t=286569 See post four in this thread; stolen/stripped /recovery http://www.camaro5.com/forums/showthread.php?t=394151 So if it's the same car, there is your history. |
02-20-2015, 12:28 PM | #14 |
Drives: None Join Date: Jan 2015
And yes it's a 1LE. The T in the vin says it's a 1LE 2SS manual car.
http://www.***********.com/1le-specs.php 2013 1LE VIN DECODER 2 Canada G General Motors 1 Passenger Car F Camaro (Fbody ) S S = 1LE 1SS Manual | T = 1LE 2SS Manual | K= SS Auto No 1LE in Auto Trans (Note: 1LEs may either come with a T or an S in the VIN to designate manual transmission) 1 37 - Coupe 2 - Door Notchback E Restraint System W Engine Type - LS3/ J= L99 No 1LE's in L99 9 Check Digit ( Could be 1-Thru-9 Digit ) D Model Year C=2012 D=2013 E=2014 F=2015 9 Plant Location - Oshawa #1 1 5 3 6 Vehicle Sequence # 8 5 |
