Old 03-30-2010, 10:03 AM   #141
alex33x
Drives: 2013 Camaro ZL1
Originally Posted by Doc View Post
How are you dealing with the speedometer? Are you able to recalibrate it for the new wheel size?
This is really easy to do, its so easy its not worth pedders mentioning it.
Because you can do it with any tuner, and you dont really need to have any knowledge in tuning, you just scroll down and you can set your speedometer to the wheel size you have.
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 03-30-2010, 10:38 AM   #142
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
Originally Posted by JusticePete View Post
We moved to production, but I want to hold off on an announcement until we are closer to a ship date. This is a very special project to me. They have been years in the making. I expect them to ship on my birthday
Well I hope it is soon so I can help you celebrate!
Figure I can be the test car for the second set....bet you are already running them.
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 03-30-2010, 12:32 PM   #143
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
My birthday ios getting very close...
JusticePete is offline   Reply With Quote
Old 03-30-2010, 12:54 PM   #144
RichJ.
Shop Owner
Drives: 1 ton silverado
If you like the wheels on Pete's Camaro we will get them for you. In fact we have a set of the Forge Line wheels with Potenza RE11 tires mounted on them at our shop now. We are waiting for the weather to break. Then the plan is to do a base car test at the track, then install the Pedders Track II XA kit and wheels and then take the Camaro to the track again.
RichJ. is offline   Reply With Quote
Old 06-22-2010, 06:26 PM   #145
JusticePete
The RE-11 Brigestones are holding up amazingly well. We have almost 10K on them and I keep saying I'll replace them after the next track session. We'll I am driving them to the GM Nationals this weekend and plan on using them for one more track session.
This is directly related to the stability of the ZETA II chassis and Pedders suspension components. The more stable the platform the longer the tires last because they are not squirming and scrubbing away tread as you drive. Please stop by the ProCharger booth to check out the tread wear -- even with a very aggressive alignment.
Old 08-31-2010, 05:48 PM   #146
JusticePete
The Bridgestone RE-11s gave up the ghost at just under 12K. The rear were good for another track session, but the front inners were close to cords because of the just over 2 degrees of negative camber and total 1 degree of toe out we run Think about that for a minute. 12k with these ridiculous alignment specifications! If I could rotate front to rear (I can't as the offsets are different) we could easily have extended the life to 15K or more.
The more stable your suspension is (Pedders bushes, coilovers and bars keep the 5th Gen suspension well controlled) the longer you will be able to run your expensive performance tires, even with aggressive alignment settings.
Old 09-06-2010, 04:20 PM   #147
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
wow, what a wealth of info this thread has become...
so my first question is will PEDDERS be releasing a suspension kit that will be needed to run this same wheel and tire combo..
i am very interested in this set-up, and would hope that it could be had with just springs, swqays and bushings...
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
1999 HUGGER SS SOLD :(
400rwhp (3375lbs)
2002 YELLOW Z06 SOLD :(
360rwhp (3040lbs)
2013 CAMARO ZL1 COMMING SOON
M6HuggerSS is offline   Reply With Quote
Old 09-06-2010, 08:42 PM   #148
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Pete, after reading this thread over again, how much of a handling difference will be made to a stock SS Camaro in your opinion, by just switching from the stock 245/20's & 275/20's to 275/19 Fronts & 305/19's Rears? Before any coilovers, bushings and sway bars are added.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
Old 09-07-2010, 12:56 PM   #149
JusticePete
Great question.
Understeer will be reduced. The car will be more planted with superior rubber. The 305/30/19s up front will cause the front end to search because of the compliance in the springs, dampers and radius bushes. You will notice more body lean and roll because the grip will have increased and you'll be taking the same corner faster. The suspension will struggle to keep the front rubber planted because once again you'll be able to operate at higher speeds and the OE dampers and coils are a bit light for this wheel and tire fitment.
It will be better, but not maximised for the new wheels and rubber.
Old 09-07-2010, 04:00 PM   #150
JusticePete
i am very interested in this set-up, and would hope that it could be had with just springs, sways and bushings...
Yes we are and some of the components are now GMPP products. You can order the Justice Package through your Pedders Suspension Specialist, your local GM Dealer or Pedders USA. All of the components are available individually as well.
Old 09-07-2010, 07:00 PM   #151
M6HuggerSS
M6HuggerSS's Avatar
Drives: Crane Truck
Great news... so is the JUSTICE package refering to the suspension, or the wheel tire combo or BOTH?
1998 Z28 M6 SOLD :(
315rwhp (3500lbs)
400rwhp (3375lbs)
360rwhp (3040lbs)
Old 09-07-2010, 07:02 PM   #152
JusticePete
Suspension. Most Pedders Dealers got hooked up with Forgeline after our first track session so you can get your wheels from them when you order your Justice Package. Not all are Bridgestone Dealers, but that should be no issue as they all work together. If you need help arranging a complete package feel free to give me a call.
Old 09-07-2010, 08:06 PM   #153
OldJedi
Use the Force
OldJedi's Avatar
Great question.
Thanks Pete, I really appreciate the expert advise.
Old 09-30-2010, 10:53 AM   #154
JusticePete
I was over in the tire section of the forum answering a few questions about wheel and tire size. This thread answers a lot of those questions so I decided to remind people it is here as a resource for more than wheel and tire selection.
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 01:25 PM
JP Got Bored or Maybe Lost His Mind JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 0 11-26-2008 04:18 PM
Pedders partnering with GM Racing on Camaro suspension Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 6 09-30-2008 12:14 PM
