07-23-2014, 08:09 AM | #1 |
SS M6: Jumpy 2nd gear?
I'll preface this with the fact that I'm not a new manual transmission driver by any means:
Has anyone else had trouble with 2nd gear on the SS? I have a 2014 1SS that I've been driving for about 2000 miles now, and I just can't seem to guarantee a smooth 2nd gear. First and reverse require a mild amount of riding the clutch, pretty typical. 3rd-6th are smooth and effortless nearly 100% of the time. 2nd gear just seems to give me a hard time more often than I would like to admit, significantly harder than 1st from a stop, which makes very little sense from a transmission/gear ratio perspective. What rpms/mphs do you find yourselves shifting at smoothly in 2nd gear? |
07-23-2014, 08:42 AM | #2 |
This is my second manual trans 5th Gen. Practically all my other cars, from a Toyota Supra Turbo to even manual transmission Toyota FJ Cruiser didn't require the same clutch manipulation.
I find myself having to ease the clutch pedal out slower than you would normally expect to get that perfect shift. I understand this more when I'm riding passenger to friends/family that drive my car and are too just too quick. First and second gear just buck and jump like crazy. With the small adjustment to my driving habits I can shift at any RPM smoothly. |
07-23-2014, 09:03 AM | #3 | |
Where would you put your typical shift on mild acceleration from a stop? I'd say for me it's 1st to 2nd by about 10mph, shift @ ~ 1200RPM. If I wait a lot longer than that then skip-shift comes into play >16mph or so. Maybe I'm taking it too low? Any thoughts on the matter would be great. On a side note, I'll 1st to 3rd for higher RPM takeoffs since it's simply smoother - or I'll just start in 2nd gear from a stop if I'm going to slip it anyway. |
07-23-2014, 10:01 AM | #4 |
Drives: 2010 CGM Camaro 2SS/LS3 Join Date: Oct 2013
I skip second a lot during normal driving around town. Usually go right to third. 2nd in these cars has triple syncros where the other gears only have two.
I do notice the same thing for me too, the clutch pedal sometimes makes it a bit hard too because of how it tends to push back a bit hard at the engagement point.
2010 2SS
BMR 1" Springs Koni Orange struts/shocks 1LE rear sway bar SRP Racing Pedals Hurst Billet short shifter Square tire/wheel setup Elite Engineering Catch Can Stainless Power longtubes/highflow cats K&N Typhoon CAI RPM Motorsports of Garner, NC dyno tune (421 RWHP) |
07-23-2014, 02:04 PM | #5 |
I put my heal into the floor and use my foot as a lever. Makes shifting in any gear much smoother then fighting the spring with your foot in mid air while your moving.
07-23-2014, 06:47 PM | #6 |
Drives: 2014 Camaro SS Join Date: Jul 2014
Damn the skip shift....have u tried changing trans fluid? Alot of guys are switching it out for Redline D4 ATF and having instant results. Prob cheapest thing to try....if not, an IdealG master cylinder, seperate clutch reservoir, and a Tick Perf. Braided line seem to be the fix.
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator 1LE Strut Tower Brace GMPP Track Pack Axleback Halltech CAI Fuse Pull Mod |
07-23-2014, 07:50 PM | #7 | |
07-23-2014, 08:16 PM | #8 |
I have the Ideal G master cylinder, reservoir and royal purple fluid on mine, it did seem to help smooth up shifts.
2010 2SS
07-25-2014, 03:44 AM | #9 |
Why not try starting in second? I never use first unless im in a hurry, or on a hill. I just hate having to shift halfway through every intersection to avoid sounding like an A$$ at 2-3 thousand RPM. Also this was before my cam, if you are cammed this option goes out the window. food for thought
08-01-2014, 10:04 PM | #10 |
Drives: 79 transam with 582cid dart motor Join Date: Jun 2010
My .02. 1200 rpm is way too low to shift.personally I shift around 3000 or so. Even before I put in a cam. Personal preference..I like to lazily run the motor up a bit. I have noticed a little grind when speed shifting tho.
2010 Camaro (inferno orange, 2SS, RS and such) cat backs, catch can, CAI on the way 79 Transam, 582 cid dart motor 779hp 315's out back 40spline gdaxles tko tranny |
08-04-2014, 07:54 AM | #11 | |
3k RPM in 1st would likely put you at about 27 mph - I'd go straight to 3rd at that speed, depending on the road/traffic. |
08-05-2014, 10:48 PM | #12 |
I shift between 2000-2500 normally...averaging 17mpg...i cant stay out of gas lol.
08-06-2014, 02:08 PM | #13 |
Drives: 2014 1LE 2SS coupe Join Date: Apr 2012
My 2nd gear is terrible...but I think my Hurst shifter is to blame when it was stock the gears would go in perfect, now I have to play with the clutch, and if I race from a complete stop at the drag strip 2nd doesn't go in/ grinds until the revs drop under 4k it's ridiculously annoying..so I stopped trying. I installed the Hurst at 5k car now has 18k not sure if the clutch or slave are to blame
08-08-2014, 11:41 AM | #14 | |
I started slowing down the shifts and it seems to help.
2010 2SS
