Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 06-18-2016, 08:54 AM   #1
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
ADM Performance AGP Twin Turbos
So it's all done and drove it 950 miles home last Thursday and Friday. What an awesome running car. The fit and finish is better than I ever expected thanks to Andy and crew at ADM Performance. Drivability is nearly as good as stock although I will miss the lope of the BTR Stage III cam, LPE GT9 is installed now to compliment the turbos. It is tuned for 91 octane and E85 both with flex fuel sensor installed. Low and high boost are selected by a simple toggle switch depending on which fuel is in the tank. I've yet to run E85 and high boost because I want to get used to how the car runs, completely different animal now.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 06-18-2016, 09:28 AM   #2
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Jeez that thing is nasty, you need to make some videos ASAP.
Dmpsix is offline   Reply With Quote
Old 06-18-2016, 11:52 AM   #3
Redlineviper
Redlineviper's Avatar
Drives: 2013 ZL1
Very nice! I see some differences between yours and mine. What intake do you have? What size turbos? Congrats. You will absolutely love the turbos. Had mine on for over a year and have zero regrets.
Redlineviper is offline   Reply With Quote
Old 06-18-2016, 02:53 PM   #4
ZL1Kid_AL
ZL1Kid_AL's Avatar
Drives: 2014 ZL1- Summit White M6
Holy Torque Curve.... Nice numbers
750whp @ 13psi Garage Built on Jack Stands.. 850++ 100 shot of sauce
ZL1Kid_AL is offline   Reply With Quote
Old 06-18-2016, 04:35 PM   #5
CodemanZL1
CodemanZL1's Avatar
Drives: 2014 ZL1
That is awesome, very clean! Definitely need some videos
Hope to get my ZL1 in their shop eventually...
CodemanZL1 is offline   Reply With Quote
Old 06-18-2016, 08:25 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Good gravy those numbers are insane!
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 06-18-2016, 11:29 PM   #7
cplhester
cplhester's Avatar
Drives: 2013 Camaro ZL1 Manual
He has my ZL1 right now doing a 417 motor. Can't wait to get it back!
cplhester is offline   Reply With Quote
Old 06-19-2016, 09:37 AM   #8
owhite3003
Z-BEAST
owhite3003's Avatar
Drives: 2013 JDP ZL-850 Track Spec ZL1,
That is saweet!
owhite3003 is offline   Reply With Quote
Old 06-20-2016, 09:48 PM   #9
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
I'm just curious for you personal opinion on this vs your heartbeat setup
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 06-20-2016, 09:57 PM   #10
Eric-MPD1.com
Drives: Cool parts for cool cars
WOW!
Eric-MPD1.com is offline   Reply With Quote
Old 06-21-2016, 02:34 PM   #11
white1LE
white1LE's Avatar
Heartbeat
Well, good question. I loved the Heartbeat because of the low end torque and it came on instantly, like yours does I'm sure. I'm getting used to this and liking it more and more. Doesn't spool up until 3500-4000 but tap shift it down and it's on!
13 ZL1 A6
1000rwhp
Old 06-21-2016, 06:49 PM   #12
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
Very Nice Build!
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 06-21-2016, 07:31 PM   #13
Scuzz
Scuzz's Avatar
My plan right now is probably a 4l80 and adding a 150 shot. To run the 1000/1000 to wheels (or about that). I considered your option, but I kinda like the torque from out the gate.
Play with your setup a little and give me your final opinion on the two. Basically I'm going to have what I have now and then what I have with spray. ( my two settings hahah) just want to know what you think you lost and gained going to turbos
Old 06-22-2016, 07:58 AM   #14
white1LE
white1LE's Avatar
Will do. Thanks!
13 ZL1 A6
1000rwhp
