12-10-2017, 12:29 AM | #99 |
Drives: 2017 Summit White ZL1, M6 Join Date: Jan 2017
I’d be curious to see how each M6 owners clutches hold up? I already replaced mine at 7700. Granted, I raced mine. I also tested the hell out of it. But I still think the amount of power or timing being pulled, has to have some impact on them being worn out early. I’d don’t know...maybe.
2011 Dodge Ram 1500 Longhorn Laramie
1966 Chevelle SS 396 |
12-10-2017, 06:20 AM | #100 | |
Thank you Al Oppenheiser!
GM made the right call here - by giving us the choice.
It's a natural consequence of "we honor the warranty at the track." They have engineered the car and it's control systems to protect the drive train from the driver (at the track, etc.). So they ended up with the consequences: driveability (bog) and the wearable bits (clutches). Kittys throw driveshafts. 2018 Mustangs with their incredibly hard launching will turn out to have something fail ... it's just a matter of time. And since neither FCA nor Ford honor the warranty at the track, they don't give a rats. If GM gives us back the driveability (eliminate the bog completely) then driveline stuff will most certainly break. And then they'll have to rescind the track warranty or Molly will kick Al's ass. So they have given that choice to us, the owners. Track your stock car all you want under warranty and live with the TM bog, or tune out the TM on your car and void the warranty. The problem is DD and light street driveability... and they should have been able to reduce the severity of the timing pull at lower dynamic torque. Obviously something kept them (or is keeping them) from doing that... some weak link in the driveline. |
12-10-2017, 09:11 AM | #101 | |
Drives: '17 ZL1 Join Date: Jul 2016
To your point something "is keeping them" from releasing the update. My guess is the cost of the update. Plus I believe the improvement would be significant. We'd probably go from 12.1-12.3 quarter miles to 11.5-11.8s. I'm sure they'd rather associate that improvement with the 7 Gen Camaro. Drive a '17 M6 ZL1 at the dragstrip for a few passes. Once you do, it's obvious the car has a problem. It isn't just drivetrain protection at play. Hell, the A10s are almost a full second faster in the 1/4 mile. I'm sure the A10s have similar drivetrain protection. The A10 should be faster, but not a full second. It's obvious there's a problem. |
12-10-2017, 07:50 PM | #102 |
Hey guys.
If you're interested in a resolution to this problem. Please show your support for its corresponding Ask Al thread. http://www.camaro6.com/forums/showthread.php?t=515791 I'm not exactly sure what the criteria is for getting it promoted to the official poll, but please post something in the thread. Even if it's just a "+1" to show your support. Thanks! |
12-10-2017, 08:03 PM | #103 | |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
12-11-2017, 01:29 AM | #104 |
Been trying to think of things to keep the sections alive. I posted this in Travis’s Ask Al but I will also post here to see if anyone else has experienced this. Or maybe have something to add.
“Does anybody else’s manual take off from a stop without using the throttle? I mean in no way whatsoever? Basically, I’m sitting at a stop and I just let clutch out slowly not even touching the gas until the clutch is fully engaged. You can do this in reverse as well. And on hills! I’ve never experienced this on any other car in my life. Maybe a tractor. Anyways, if this is an option this might be the reason that the car boggs on takeoff. The torque mgt might be getting too much input from the throttle position at one time. It might be the explanation about why first gear feels so tall. It could also explain the difference in taking off each time and the car does not respond the same to your foot position. If that makes sense?” Thoughts?
12-11-2017, 08:47 AM | #105 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
12-11-2017, 04:18 PM | #106 | |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Sent from my SM-G955U using Tapatalk
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
12-11-2017, 04:58 PM | #107 |
Let's do everything we can to ensure this topic makes it into the next Ask Al poll. If you haven't done so already, please post a "+1" or something similar into the Ask Al thread:
http://www.camaro6.com/forums/showthread.php?t=515791 When the time comes to select questions for the next poll, I'd like to make sure our view/post counts are representative of how we all feel about this issue. "Ask Al" may be our best hope for a resolution. Please post. It'll only take a few seconds. Thanks again! |
12-11-2017, 06:54 PM | #108 |
Sellin Chevy's since '06
Just stumbled upon this thread. I got back from a track day event yesterday and watched my buddy with a '17 M6 bog real hard with heated up drag radials. I also have a drivability issue in my '18 M6 car with constant complaints when people drive my car.It seems like there is a double clutch engagement and it wanting to stall off the start. This makes total sense it's a software issue. A buddy of mine who had a '17 SS/1LE that drove mine stalled it. He said it was waaay different than his M6 SS. I also have stalled mine several times too. I am willing to bet the launch/drivability software issue isn't fixed for 2018 MY.
To clarify, I have not launched my car yet but the drivability off the line kinda sucks.
'19 Z06-7Speed and lowered on stock bolts
'02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub40K orig miles. https://youtu.be/h6faSdcvNew TRADED!'17 ATS-V Coupe w/ Carbon Black pkg https://youtu.be/GH_t-R-TJV0 SOLD! '18 ZL1 Mosiac Blk SOLD!'16 SS Sedan-Forgestars/ARH/rotofab TRADED!2014 SS Sedan SOLD! 2013 Blue Ray1SS/1LE 1of20. TRADED! 2012 White 1SS/RS |
12-12-2017, 07:33 AM | #109 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
(moved out of the Ask Al thread) Quote:
Does this happen on launches and street starts from a full stop made in 2nd gear? Norm
'19 WRX 6M (the family sedan . . . seriously) |
12-12-2017, 04:22 PM | #110 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
--Cal |
12-12-2017, 05:04 PM | #111 | ||
Cal
Sure I agree that the main purpose of the "Manual Transmission Protection" (MTP) feature is for Track Warranty Protection but I feel like it could have been (and can still be) calibrated for a higher torque with minimal risk. Even a slight increase could yield significantly better 60-ft times. As many others have said, it's embarrassing for Chevy to fall on its nose at track events all over the country. Travis' research on the eLSD calibrations have convinced me that this part of the problem is not by design. It is one of those engineering ghosts that appear only after owners "wring out the bugs". Seems that this could very likely interact with the MTP logic to compound the bogging issues. --Cal |
12-13-2017, 12:17 PM | #112 |
Drives: 2017 ZL1 A10 Nightfall Gray Join Date: Jul 2017
I found a video where the bogging is so apparent, its sad. Listen to this motor just die off the launch.
https://youtu.be/Ppn2NfC9stE |
