Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 10-09-2018, 09:59 AM   #1
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Michelin Pilot Sport 4S
I just ordered some of these for my 1LE
305/30/20
for the rear
Anyone here has had these on there car and what do you think ?
I had Nitto 555G2 before but with bigger tires in the rear (315/35/20)
I went smaller cause they didn't have it for that size.
Any personal experience would be appreciated.
I should receive it by tomorrow.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 10-09-2018, 10:55 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
305/30? Keep in mind this tire will be ~1.2" smaller in diameter compared to the factory 1LE rear tire (305/35). What size tire are you running on the front? If 285/35, a 305/30 rear will be ~0.65" smaller than the front, compared to ~0.55" bigger with a factory 305/35.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 10-09-2018, 11:00 AM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Originally Posted by KillboyPowerhead View Post
305/30? Keep in mind this tire will be ~1.2" smaller in diameter compared to the factory 1LE rear tire. What size tire are you running on the front?
Goodyear F1 G2 has the 285/35-20 @ 27.9"
Michelin Pilot Sport 4S 305/30-20 is 27.2"
So 0.7" diameter difference
zz430camaro is offline   Reply With Quote
Old 10-09-2018, 11:42 AM   #4
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
The MP4S are great tires. I have them on my 2013 1LE in OEM size. Less ultimate lateral grip than the G2 (when warmed up), much better cold grip and incredible wet grip (better wet grip than any other street tire I've had).
They feel a little more compliant in the sidewall. Great street tire, great rain tire.
I have 5000 or so miles on them now.
bkevind is offline   Reply With Quote
Old 10-09-2018, 12:52 PM   #5
rgrmoreira13
well I have a 1LE but I got aftermarket wheels.
The 1LE wheels are 20x10 in the front
and 20x11 in the rear.
But for now I am using a wheel that are a bit smaller all around
20x9.5 in the front
20x10.5 in the rear
The tire size I have in the front is 275/45/20
In the rear I have 315/35/20 in the rear
I hope that this information would help
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 10-09-2018, 12:55 PM   #6
rgrmoreira13
I got them for the front and YES they are amazing
I should get these same tires tomorrow for the rear and I can't wait to say goodbye to the Nitto 555G2
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 10-09-2018, 11:52 PM   #7
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
Best tire I have had on my Camaro. Beats the MPSS by a long shot. 285/35-20 all the way around.
Scott@Bjorn3D is offline   Reply With Quote
Old 10-10-2018, 07:01 AM   #8
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
Wonder how a 305/30/20 square set up would be on the 1le? Would this 305/30/20 fit up front on the ZL1/1le wheel? I was thinking about going to a 295/30/20 square set up, anybody have experience with the 295/30/20?
Matty Ice is offline   Reply With Quote
Old 10-10-2018, 07:26 AM   #9
ZEN357
ZEN357's Avatar
Drives: 1991 Z/28 Convertible
My Late Father, God rest his Soul, swore by Michelins!!! That was all he would ever run on his cars. If you tried to talk about any other tire brand he would shut you down in a heart beat!!! And honestly he never had any issues with them, the lasted and ran great!!!
ZEN357 is offline   Reply With Quote
