01-12-2024, 11:04 PM | #1 |
Drives: Camaro SS Join Date: Dec 2020
FE3 to 1LE Rear Sway Bar Conversion
Hey all. To give you a little background I've had my camaro 2ss rs for 3 years now. I got it lightly modified. Suspension wise it has H&R lowering springs and I just got new tires F:20/40/265 and R:20/40/295.The car handles better with the wider tires, but I still feel a lot of body roll.
I did some research and it seems like converting the FE3 to FE4 is the way to go for a big improvement. I also heard that getting just the rear 1le / zl1 sway bar with the stock ss front is a pretty good setup (F:23mm / R:28mm). Would anyone know all the parts needed to run the rear 1le sway bar? Part numbers would be awesome too. From what I can gather I need: - FE4 rear lower control arm - FE4 rear drop links - 1le rear sway bar Anything I'm missing? Thanks in advance! |
01-13-2024, 02:17 PM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
That’s all that is required. You need the lower control arm because the end links mount further outboard. Nothing else changes. I had to remove mine to install a 15 inch conversion with BMRs extreme sway bar, that’s how I know.
01-17-2024, 10:44 AM | #3 |
thank you! Appreciate the confirmation
01-17-2024, 11:03 AM | #4 |
Does the OEM bar come with new mounts or is that a separate part #. The aftermarket bars typically come with new mounts but I'm not sure about OEM.
01-18-2024, 08:49 AM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
OEM bars have the mounts on them, but you do have to order the links to the LCA.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-19-2024, 07:51 AM | #6 |
BMR TCA028 or similar has provisions for both. 1st pic used BMR bar and inboard mount. 2nd pic is when I changed to outboard mount with a JPSS sway.
