Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 06-16-2013, 03:41 PM   #1
BAD ZL1
BAD ZL1
BAD ZL1's Avatar
Drives: 2013 VIN 48 Victory Red ZL1!
run flats?
Is it common for tire companies to come out with run flats after a few years of a new tire dimension on a car? I am thinking by the time I need tires, run flats would make sense for a car with no spare or jack etc. What are the disadvantages of run flats for daily driving? I think the Vette guys have had them right? I know nothing on the subject its pretty obvious.
BAD ZL1 is offline   Reply With Quote
Old 06-16-2013, 03:57 PM   #2
Rhyder
Drives: 2012 45 Anniversary Vert
they cost crazy amounts of money. Dont know if they still due, but they used to need to have a set up run on the car to support them. They dont last very long at all.......
Rhyder is offline   Reply With Quote
Old 06-16-2013, 04:04 PM   #3
DavidW
Drives: 2013 ZL1 Vert Auto IOM
I don't know much except that they tend to perform worse as far as traction goes, and have a much rougher ride because the sidewall is so thick, I would personally just get a spare tire kit from performance spare.
DavidW is offline   Reply With Quote
Old 06-16-2013, 04:43 PM   #4
Ocikat
Ocikat's Avatar
Drives: 2012 2LT 45th convertible
I have run flats that came installed on my Mini, the biggest advantage is that if you do have a flat you can still get home or to the dealer or tire shop, You also don't have the weight & space in the car of the spare and jack etc. Here's the bad news,....... (1) you can't repair them so after getting a flat you will have to have a replacement. (2) they are expensive you will probably pay $ 300 - $500 for 1 tire, (3) rubber compounds will always be limited to to the construction and the requirements needed to run on 0 pressure so they are not the best performance tire that can be had if that is what you're looking for, they aren't bad for everyday driving but it is a compromise. I'm sure the sizes availble is market driven so I don't know if the stock sizes for our Camaros are or will be available but a quick check with the major tire companys could probably answer that for you
Top Ten Reasons I Procrastinate
1.
Ocikat is offline   Reply With Quote
Old 06-16-2013, 10:28 PM   #5
kmthor00
Drives: 2013 ZL1 Black
Not true on number 1, I've spent years on the corvette forum, owned 3 C6's, as long as the damage is not on the sidewall it can be repaired.
kmthor00 is offline   Reply With Quote
Old 06-17-2013, 06:57 AM   #6
URBAN LEGEND
URBAN LEGEND's Avatar
For sure the tread side can be repaired.
URBAN LEGEND is offline   Reply With Quote
Old 06-17-2013, 09:23 AM   #7
pannhead51
pannhead51's Avatar
Drives: 2SS convertible
The Bridgestone runflats on my wife's BMW were $560 each !!
pannhead51 is offline   Reply With Quote
Old 06-17-2013, 10:43 AM   #8
caper
Drives: 2010 IOM 2ss/RS
I have them on the rear, sportmaxx 315's , they work pretty well, and I like that I don't need to be worried about losing a rear tire and being stuck...oddly enough, I have gotten 2 flats in the front. tire life on my first set of them was better than the stock Pirellis.
caper is offline   Reply With Quote
