11-13-2016, 01:31 PM | #1 |
Drives: '13 ZL1 Convertible Join Date: Apr 2016
Confirmed rear main is leaking...
...so looking for any pointers or *Ah-ha*'s to look out for in removing the automatic transmission. I've found plenty of threads on the manual, but not the automatic.
Also, any recommendations on a replacement seal? |
11-13-2016, 03:02 PM | #2 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
No Warranty?
Bryan 2018 ZL1 M6
11-14-2016, 09:00 AM | #3 |
Due to this car having the KaTech Engineering Stage IV kit installed in it, GM does not honor the warranty (which is COMPLETE and TOTAL B.S.!)
11-14-2016, 09:11 AM | #4 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Stage IV kit? Isn't that 775hp?
http://katechengines.com/performance...12-camaro-zl1/ And you think it's "complete and total bs" that GM won't cover your rear main seal leaking under warranty? Seriously.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
11-14-2016, 09:19 AM | #5 |
guaranteed the crankcase is pressurizing and caused the oil leak. Add a crankcase breather or mighty mouse catch can with breather to alleviate the crankcase pressure. The extra boost is the culprit.
11-14-2016, 11:44 AM | #6 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
The kit should have included the crank case breather IMHO...
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
11-14-2016, 12:10 PM | #7 | |
11-14-2016, 12:13 PM | #8 |
Agree. Purchased and installed the Elite Engineering E2-X catch can back in June.
11-14-2016, 12:48 PM | #9 |
Drives: 2010 Camaro Join Date: Nov 2009
The E2-X will eliminate any possible crankcase pressure issues w/out a breather breaking the system to vent. To replace the rear main seal, the trans is not hard to drop out either way, for the auto take the bolts loose that attach the torque converter to the flex-plate and then after unhooking cooler lines and harness and shifter, un bolt from engine and slide back a few inches and it will drop down.
For manual, you can disconnect harness and shifter and the hydraulic line for the release bearing and pull it out of the clutch/PP, but the input shaft requires you to come back a bit further before you can drop it down. Use a seal puller to remove the old one, and make sure the new one is tapped into place evenly with a proper sized seal installer if you have one. Put NO sealer on the seal, clean rear cover area where the seal seats and then install it dry. Good luck and let us know if you need more help! |
11-15-2016, 12:05 AM | #10 | |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
11-22-2016, 03:20 PM | #11 |
Yes they do, however it's only 12 mo./12K miles. The work was done during 2013 via the original owner. I did not procure the car until April 11, 2015.
11-22-2016, 03:22 PM | #12 |
O.K. Finally getting around to crunch time, so I need opinions on rear main replacement seal. Here's what I've found so far. Thoughts?
https://www.summitracing.com/parts/t...make/chevrolet http://www.jegs.com/i/JEGS-Performan...50325/10002/-1 I reached out to Katech to get their opinion as well. I hope to hear back from them tomorrow. |
11-22-2016, 05:50 PM | #13 |
Drives: 13 zl1 Join Date: Apr 2013
Gm part # 12639250. Its the whole rear plate with the gasket and the rear main. Thats the best way to do it.
11-22-2016, 09:16 PM | #14 |
The Timken part from Summit would be good. They are a well known manufacturer of seals and bearings. The GM part is most like made by Timken.
Bryan 2018 ZL1 M6
Tags |
automatic, removal, transmission |
