dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Z/28 Forum - Z/28 Specific Topics
Old 02-16-2016, 08:17 AM   #1
Z/28Dan
Z/28Dan's Avatar
Drives: 2013 HWSE Indy Festial #26
Stuffing your Z/28 full of tires
I'm headed to VIR for Winterfest this weekend. Since I haven't found the perfect trailer yet, I'm thinking about stuffing my track wheels/tires into my back seat and front passenger seat. I think I saw a guy on the ZL1 forum do this. Just wondering if anyone has tried this and will all four tires fit?
I know I could try it myself, except right now my Z/28 is stored off sight.
Things that make you go hmmm...
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan
Z/28Dan is offline   Reply With Quote
Old 02-16-2016, 08:30 AM   #2
Splat1two
Drives: 2015 2ss 1le
Ive seen a set of ZL1 wheels with 305's on them, stuffed in the back seat and trunk of a 1LE. Best part was the bungee cords connected to the trunk lid.
Splat1two is offline   Reply With Quote
Old 02-16-2016, 08:50 AM   #3
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
One in the trunk, two in the back seat with it folded down and one in the passenger seat. It's not easy to get them in and out either.
Thor142 is offline   Reply With Quote
Old 02-16-2016, 08:55 AM   #4
Z/28Dan
Z/28Dan's Avatar
Z/28 back seat does not fold down, but I think I can get 3 in the back since they are 19's. This is going to be interesting, but there's no way I'm going to put unnecessary miles on the Trofeos. VIR is a long trip for me. 194 miles one way.
Dan
Old 02-16-2016, 09:15 AM   #5
Foxrus14
Drives: 2018 ZL1 1LE
Send a message via AIM to Foxrus14 Send a message via Skype™ to Foxrus14
Rent a Trailer for the weekend...
Foxrus14 is offline   Reply With Quote
Old 02-16-2016, 09:20 AM   #6
Thor142
Thor142's Avatar
I only folded the seat down cause I was too lazy to cover the upholstery. You'll get 2 in there but not 3
Old 02-16-2016, 09:53 AM   #7
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
When I switch from winter tires to summer (visa versa) I put the rears in the back seat and the fronts in the front seat. Tires are not on wheels. Tires are in tire covers from tire rack.
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 02-16-2016, 10:14 AM   #8
2015Z28
Drives: 2015 Z28 #516
The rear seat does fold down. There is no strap like the others but the latch mechanism is there. You have to use a finger through the trunk to release the seat latch.
Keep in mind the seat is only Styrofoam under the upholstery.
2015Z28 is offline   Reply With Quote
Old 02-16-2016, 11:02 AM   #9
Z/28Dan
Z/28Dan's Avatar
Did not know it folded down. Thanks.
Dan
Old 02-16-2016, 12:17 PM   #10
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
Did this twice with my 2nd set of stock wheels and trofeos. Get large thick garbage bags for each wheel and a few moving blankets ($9 harborfreight). I'm 6' 1" so the wheel behind my seat went sideways so it did not affect my seat then the other wheel on passenger side at first sat perfect in the back seat facing forward...but...then the wheel also facing forward in the passenger seat obstructed the side mirror...so I changed the wheel sideways in the passenger back seat but angled enough so the passenger seat could recline enough to see the mirror around the passenger seat tire. Then I used the seatbelt through the passenger seat wheel to secure it in locking mode. I also used moving blankets under and around all wheels...the most critical area is not scuffing anything especially the dash. In the trunk you must remove the cover to fit a wheel in so I put another moving blanket under the wheel and it sits perfect in the wheel well and then put gear over it..jacks etc. It works!!!
also I do not think it is possible to get 3 in the back seat folded down or not and I too never knew it folded...is that in the manual?
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
Old 02-16-2016, 12:56 PM   #11
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Ive done one in the trunk, two in the back seat and one on the passenger seat in my ZL1
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 02-16-2016, 01:20 PM   #12
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
You can remove the rear seat entirely and then you will have much more room. The rear seat brace is supposedly part of the rigid structure but I can't believe that it does very much. I ran at VIR in my ZL1 with no rear seat and really didn't see any difference in handling at all.
Old 02-16-2016, 01:21 PM   #13
Stephen12ZL1
Drives: '21 ZLE A10
This is new to me as well. I honestly never checked for the latch.
Old 02-16-2016, 01:29 PM   #14
AG1LE
AG1LE's Avatar
Drives: '14 1LE
3 in the back seat (pictured) + one in the front seat
AG1LE is offline   Reply With Quote
