Old 03-23-2018, 09:35 AM   #1
bmclaurin
Drives: 2018 Camaro ZL1 (A10)
Throttle body bolt torque spec?
This is probably a dumb question, but is there a torque spec for the 4 mounting bolts? I just swapped mine out for a TM, and I couldn’t believe how loosely torqued the stock TB was. I snugged up the new one pretty decently (definitely more than the stock one was). Not sure if the torque is super critical here but thought I’d ask. Rather be safe than sorry. Thanks.
2018 ZL1 A10 | Roto-Fab CAI | Mamo Ported TB | HRE FF04 | Michelin PS4S 285/305
bmclaurin is offline   Reply With Quote
Old 03-23-2018, 09:38 AM   #2
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
89 lb in.
Sent from my SM-G950U using Tapatalk
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 03-23-2018, 11:35 AM   #3
bmclaurin
Thank you!
Old 03-23-2018, 11:57 AM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
firm...not psycho tight...just kidding. Torquing isn’t absolutely necessary.
