Old 03-26-2019, 01:56 PM   #1
I1LEST
I1LEST's Avatar
Drives: 2017 Chevrolet Camaro ZL1
ZL1 A10 Fuse Pull + Cat Delete
I finally got around to the "51" fuse pull and secondary cat delete today. I have to say I finally have some exhaust sound in 9th and 10th gear (mostly thanks to the fuse pull). Before, I could feel the back-pressure of the closed valves when in auto mode when I slowly increased pressured on the gas pedal. It was completely silent until I hit 2K RPM. In manual mode, hitting the gas in 9th or 10th resulted in no exhaust sound whatsoever.
As for the secondary cat delete, I sense there's only a minor bump in sound, but only in higher RPMs. Hard to tell though. May be time to go with a Corsa Extreme axle-back to get the bump I need.
I1LEST is offline   Reply With Quote
Old 03-26-2019, 02:21 PM   #2
2ltrgsr
AXLERODZL1
2ltrgsr's Avatar
Drives: 2019 Riverside blue ZL1 Camaro
Delete the primary cat.... that will definitely wake it up.
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout
Roto-Fab Big gulp
103 TB
Lingenfelter Lower Pulley(9.17)
1 7/8 ARH headers and Exhaust
Meth injection(single nozzle)
733whp/788tq
2ltrgsr is offline   Reply With Quote
Old 03-26-2019, 03:58 PM   #3
I1LEST
I1LEST's Avatar
I thought about that, but then I'd break the warranty for sure after tuning.
Old 04-04-2019, 08:20 AM   #4
Craighole
Drives: 2019 ZL1 / Red Hot / A10
Doesn’t deleting the secondary cat technically void the warranty?
Craighole is offline   Reply With Quote
Old 04-04-2019, 11:42 AM   #5
TeleZL1
TeleZL1's Avatar
Drives: 2018 ZL1
2nd Cat delete "Technically" yes...but nothing like going in the ECM. Once you tune you are 100% on your own.
If you throw a rod and all you had was the 2nd cat delete....I would like to think most stealerships would still work with you but you do it after a tune....no way!
TeleZL1 is offline   Reply With Quote
