Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 03-05-2013, 12:52 PM   #1
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Coolant pump question
What is the difference between these two upgraded coolant pumps
http://www.shop.coolerlogic.com/ZL1-...de-ZL1PUMP.htm
http://www.shop.coolerlogic.com/High...-pump-Pump.htm
Both flow 20 gpm. Would the zr1 pump not bolt straight on without modification? Trying to save a few bucks.
Please and thank you!
KKreme15 is offline   Reply With Quote
Old 03-05-2013, 03:17 PM   #2
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Nobody?
Old 03-05-2013, 03:22 PM   #3
ZL1 TIBS
Drives: 1968 Camaro, 2012 ZL1
I imagine they are the same pump, but the more expensive one is a plug and play with the correct fittings and wiring plugs. You will have to do some fabrication on the cheaper one.
ZL1 TIBS is offline   Reply With Quote
Old 03-05-2013, 04:26 PM   #4
HDRDTD
And mounting plate going by the photos.
To get the mounting plate that bolts right in, the fittings, and the plug on the wiring that'll plug right into the ZL1 harness is worth the additional $75 if you ask me.
Old 03-05-2013, 05:22 PM   #5
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
I have the $425 pump. Comes with everything you need.
The only downside is, it is a bit noisy.
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 03-05-2013, 06:29 PM   #6
crazydave
crazydave's Avatar
Drives: 2013 Camaro ZL1 M6
I just ordered one myself. Do you notice the increased noise within the cabin? I figured it would be a little more noticeable since its doing 5x the work, but I don't want it to be obvious that I have it when in the car. How much louder is it would you say?
crazydave is offline   Reply With Quote
Old 03-05-2013, 06:42 PM   #7
Blown355
Blown355's Avatar
You can definitely hear it at idle inside the cabin. But once you start moving you don't hear it. I kind of like hearing it, knowing that it's on. A few times with the stock pump I made a run then realized the pump was not on. IAT2's of 150+.
2017 ZL1
A10
Redhot with stripe
Old 03-09-2013, 12:20 AM   #8
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Save your money and buy it from jegs 219.00 fittings cost me 20.00 locally.
Flavorwrench is offline   Reply With Quote
