02-25-2017, 05:38 PM | #1 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
ZL1 1LE Brakes/Rotors....Why not CC?
It seems many Z/28 features were duplicated in the new ZL1 1LE except for the brakes....Why is that, do you think?....It wouldn't have been surprising if they had used them as on the Z/28....They seemed to have been well received on the Z/28 for track duty....and would have been a good track up-grade for this 1LE....
Pretty sure the spy shots of this car at the Ring and elsewhere showed Carbon Ceramic rotors.....Just curious....Haven't heard much about the brakes yet...Maybe I missed it somewhere.... |
02-25-2017, 06:36 PM | #2 |
Drives: RS Join Date: Jan 2013
CC are too expensive. If the car was in the $100K range maybe they could justify it.
02-25-2017, 06:38 PM | #3 |
White knuckled & smiling
Drives: '17 ZL1 AKA Perfection! Join Date: Aug 2015
The press that I read all said the CC brakes weren't really needed. Which means the cost vs. advantage was just not enough.
Good to hear the regular ZL1 (still odd saying regular ZL1), brakes are up to the task of stopping the hyped up version. They're painted red... So maybe that's the upgrade.
2017 ZL1 A10 CFHood PDR NAV NFG - Order # VCSDRJ
TPW - 3/6/2017 VIN - 1G1FK1R62H0192950 6000 - 04/05/2017 - Delivered! |
02-25-2017, 07:15 PM | #4 |
Drives: 17 SS 1LE Join Date: Dec 2015
The Z/28 would get CCB's when it comes out.
02-25-2017, 07:53 PM | #5 |
Drives: 1969 Mustang MaCh1 Join Date: Nov 2015
Probably mostly to cut on costs for a minor overall performance upgrade. The Gen 5 Z28 probably would have sold better without the added costs of CC brakes, IMO of course.
1969 Pro-Touring MaCh 1 - CHP 427w 10.8 comp - 3140 lbs. - 460 rwhp / 490 rwtqT56 Magnum || 14" 6 piston front / 13" 4 piston rear Wilwood brakes || Hydraulic clutch || 9" Detroit Locker || TCP Coilovers || Forgeline Wheels 18x10 275/35 front, 19x12 325/30 rear |
02-25-2017, 07:59 PM | #6 |
I used to be Dragoneye...
Two big reasons are likely.
#1: The Camaro team determined that the car performed as well as they needed with the large iron rotors. And the proof is in the pudding...stopping distances similar to last-gen Z/28...Motortrend recorded a 97ft 60-0 distance. Furthermore...tons of cooling elements, and raw heat capacity results in very little brake fade, if any. #2: At 64k starting price (with GG tax and destination included)...this ZL1 1LE will likely push the 71-73k range. Which is Z/28 prices...a risky move in terms of charging for a Camaro. If you add the CCM brakes, that will immediately push it into the 76-78k range. Z06 territory. |
02-25-2017, 08:03 PM | #7 |
This car is lighter than the Z/28 as well.
No doubt CC brakes would improve, but how much and at what cost? I thought I wanted them after my 1st drive in a Z/28 but sure don't want the replacement cost associated. |
02-25-2017, 08:12 PM | #8 |
How much lighter?
